SusiBus
2-pedal power Peppa Pig trike
Now in process of ordering SusiBus T6 and it has become clear that ordering options, and getting it right, is far from as easy as it should be because of ---
VW clarifications so far:
1 Diff lock
The differential rear axle lock 1Y4 is available as an option in the Dealer Order Configurator, but this was added later and so needs to be updated on the option list. The price for the rear diff lock is £470 basic ex VAT / £564 incl. VAT and it is only available on 4MOTION derivatives. With regards to functionality the rear differential lock when activated locks the differential on the two rear wheel, i.e. both wheels rotate at the same speed which makes movement on slippery surface, e.g. on ice, off-road, still possible. So, for example when driving off-road and one wheel has lost contact to the surface, mechanical rear diff lock helps to improve manoeuvrability.
2 Privacy glass
From the different glass options only QL0 and Z2C are available on California Ocean, QL4 is standard. We do not have images yet unfortunately, but I can provide a short description. So, QL4 is standard on Ocean which is the green insulating glass in the passenger compartment. QL0 is privacy glass that also provides heat insulation like QL4 but it is further tinted so it is less see through. Z2C is a pack containing laminated glass for the front side windows, privacy glass for the passenger compartment, and a laminated windshield and insulated glass for the rear window. The two latter ones come as standard on a California Ocean anyway
The story is slightly different on Beach where QL3 is standard which is green heat-insulating glass in cab and passenger compartment. As an option on Beach you can get the two packs Z2A and Z2B. Z2A contains above the already standard laminated windshield laminated privacy glass for the passenger compartment with a metal layer aiding also with noise suppression. Z2B gives you insulating green glass for the rear window and the side windows in the passenger compartment.
I think clarification of the clarification might be required ! Anyone help?
This has caused problems in the past when ordering a T5 with vehicles glass tints not fitting the customers expectations when delivered.
I have been informed that somewhere it states that the laminated glass package includes privacy glass but I believe this is only the 20% darker green tint. To get very dark windows you need optional privacy glass which is 55% darker.
Printed brochure - It been delayed again apparently they've had some sort of marketing problem that has diverted resources, oh! and last week was half term ! ! No issue date given.
So please post here any ordering problems that you're having, so we can feed it back to VW, but in the meantime if any members know the answers, please post them to save us asking unnecessary questions.
- No printed brochure available
- Online brochure with minimal information, inaccuracies and omissions.
- Dealer configurator with similar problems.
- Lack of accurate backup knowledge at VW customer service.
1 Diff lock
2 Privacy glass
