AndyFromTheBrac
Guest User
The easiest diagnostic test is;
If one side is lowering faster or sagging then swap the L & R Ram Hydraulic pipes over at the pump end. They are next to each other.
If the sagging stays on same side - Ram faulty.
If the sagging swaps sides - Pump at fault, but check Hydraulic fluid level before blaming pump.
Thank you that’s a very clear way of diagnosing. I’ll check the other posts on here as I saw the one to get to the fluid reservoir and at least check that, much obliged!
