Spare tyre removal problem
G
George Sharpe
Lancashire
T5 SE 180
Just had a flat and needed to change the wheel. Suffered the humiliation of having to call roadside service to do this as I couldn’t get one of the bolts holding the spare off. The guy who came had great difficulty and in the end sheared the bolt
So I’ve had the call for 8 years and never needed the spare. Leaning is that’s it’s worth loosening and lubricating the retention bolts occasionally
Yep. I get that. My point is the right bolt wouldn’t undo so it’s worth listening it periodically to avoid the issue I had
Please don't think it's humiliating to call for assistance. Especially if the vehicle isn't in a safe place. These guys have a vehicle that can be placed to protect yours and all the right tools for the job. If I found myself on the hardshoulder or worse on the verge of a busy A road, I think I'd wait an hour and let someone who does it for a day job show me just how good they are.
Getting the spare off is only the start of it, getting a wheel off can also be a PITA, they tend to get stuck on the hub if they’ve not been off for a while.
I've always assumed that the day I get a puncture on the Cali, will be one of the worst of my life.
The last time I jacked up my Golf the jack broke and I was lucky I didn't lose my arm.
Ten years ago someone stole the Cali spare and I replaced it with one from eBay. At the back of my mind I worry that even once I've jacked up and removed everything, the spare will be the wrong size! It has 5 holes, gotta go on right?? A call to the AA is pretty likely I'd say.
I’ve been on the tools for 45 years, in the early days at VW removing the wheels and cleaning the hub flanges and and wheel then greasing them would be part of the major service schedule, Now it isn’t,the only time they are removed in a dealership is to replace brakes, Then more often than not the technician doesn’t clean/lube them because there all on bonus, Then they impact gun the wheels on (Too tightly) Then torque up the already over tightened bolts, So yes getting the wheels of in the event of a puncher can be a real PITA when it shouldn’t be.
When you rotate your wheels use a small dab of suitable grease. They will always come off a treat when needed. And you won’t need a sledge hammer to do it.
Please also heed WG cautionary note and have a practice at removing the spare wheel from the cradle.
I swapped the spare on to the vehicle after having a puncture repaired with a plug and felt happier with the repaired tyre as a spare.
Even on a level driveway there was just enough clearance to slide the spare out without jacking the rear up.
I also managed to prolapse a cervical disc getting the new spare back into the cradle and levering the cradle back on to the retaining bolts with the wheel wrench in the slot on the end of the cradle
I called the AA and unfortunately he cross threaded the spare because he couldn’t be bothered to jack the vehicle up. It was a real problem as the thread is in the floor pan of the van. Thankfully the tyre fitter I ended up going to fiddled with it for an hour and thankfully managed to rethreaded. I darent undo it again because I’m worried the thread won’t hold!
You could probably get it re-threaded using something like a helicoil
Could not agree more. I had a puncture the other day on the A21. Called our road side assistance number and they took about 30 mins.whilst waiting I tried ti do it myself.
Took me ages to get the spare wheel out. Neeeded u tube videos
Managed to Jack it up. I thought
Nearly got the bolts of, whilst trying to the camper wanting to tip off the Jack. Luckily when my Dad taught me how to change a tyre he taught me to put the spare under the car next ti the Jack so if it falls off no damage is done.
So when it tipped off. It was ok.
Was glad when the mechanic turned up with his Jack.
He then needed to use a large mallet to get the wheel off after all the bolts were off. I would never had done it without help.
I would never try and do it again, it’s not worth it. And I will always pay for AA (or equivalent) membership
I'm glad your OK.
