Bellcrew
You can also use sport mode, coast is disabled and engine braking is effectively increased, when ACC is used the higher gears are used earlier and of course that action also disengages the coast function.Don't use it at all as I prefer to have the engine running/engaged as in cruise condition with some engine braking which isn't that much. I also don't like the engine going to idle when it may have been working hard and very hot on an uphill drag.
If there was a simple switch as in is the case with the stop/start function I'd probably use it on some runs.
I wonder how many times drivers disengage it by touching a pedal in percentage terms when it goes into coasting mode.
Another puzzle for me is that if using coasting how can regenerative energy be produced?
