VW California T5 ONLY Roof Corrosion - General Discussion
Where do you have the Roof Corrosion on your VW California?
  • Front panel only
    Votes: 198 37.4%
  • Main elevating roof only
    Votes: 80 15.1%
  • Both Front panel and main roof
    Votes: 251 47.4%
  • Total voters
    529
Anyone ever removed the plastic cap over the front cowl to see what's going on underneath, surely the original aluminium will continue to corrode?
Of course it is a manufacturing issue.
That is why (and because of the millions, or at least thousands of California's (all of them) suffer the same problem since 2004 or 2005) VW has finally caught up with the problem and is still trying to find a decent solution.
Let's all hope that this solution will be the end of our problems.
Although I don't see how the 2 small stripes of clear tape on the front spoiler here:
and here:
will solve this white stripe in the middle:
Excuse my ugly pictures. It's more cleaned now.
Have you got a clean picture of the exact corrosion on your roof?
I've got a bubble on mine, i've flicked the paint of it now, its about the size of a
big thumb but cut off just where it bends.
Mine is on the front panel under the roof seal.
I'll post a pic when i get it out of the barn next week.
Thanks. The general body shop owner down the road thinks some of it is caused by stone chip damage and suggested applying clear 3M tape to protect the capping.
The panel above the windscreen is solid, not hollow, so you won’t be drilling into it. It is not corrosion as in rusting, but Galvanic Corrosion caused by close proximity of dissimilar metals. Very common on the old Land Rovers with a steel chassis and aluminium alloy body panels.
Back, right side, roof.
Left, side, somewhere halfway. You see the front mechanism.
A bit further to the left front.
Left side front spoiler.
Middle (sorry for not cleaning it first).
Right front side, front spoiler.
This was in 2015, the original front spoiler.
I wished they had just resprayed this one, instead of taking it off and putting on a new one.
I didn't know they were going to put on a new one, otherwise I would have insisted in just respraying it on the van.
It's not big, but I didn't like it, and it was under warranty.
I don't have pictures of the original blistering on the roof, but it were little dots just above the rubber.
That time they also put on a complete new roof. If I knew then what I know now, I would have insisted in respraying the original roof.... :mad:
I don't blame them, I really blame VW for no decent solution for this 15 year old problem, without decent outcome.
Excuse my ugly looking index finger.. :Iamsorry
I thought they just covered over the original cowl with a plastic one, not removed the original, especially if it's solid as @WelshGas stated above.
I have never taken my roof seal off so who knows
what's under there.
A few glasses of milk should sort your finger nail out,
looks like a bit of calcium deficiency :D
Is it best just to do a superficial repair every few years then? Difficult light I know but you can see the blistering along the leading edge of the windscreen. The side on photo is the worst bit in the corner (you can also see what I mean about the faded roof).
View attachment 64715View attachment 64716
Your seal looks like its not touching the front panel.
Has the van had a roof job done already?
As for the roof fading, the sides look okay-ish from that picture,
could it be that the roof has never ever been cleaned on top?
Maybe try T-cutting and waxing a small area.
I’ve checked with VW and there is nothing on the system about any roof work being done (apart from a new bellows fitted a few years ago by VW). There are no leaks and we’ve have a heck of a lot of rain. Might benefit from a new seal, could be perished from all the sunshine in Spain. Might try some polish on the roof, may just lift the appearance but of course you can’t see it from ground level!
It could be that the roof just needs a good clean and polish, as
no-one has ever done it.
I will post a pic of my roof seal next week, I'm sure there is no gap
between the panels, but it could be shrinking.
If that was mine I would have a go myself..Mask Everything off really well..Rub it down really well and give it a good coat of acid etch for Aluminium in a rattle can. Then rattle can top coat and lacquer..OR get a mobile repairer to call and do it for you..Shouldn’t cost that much...
Found some Auto Glym paint renovator in the garage. Might give it a go on the roof.
Just to clarify. When the plastic cap is fitted most of the original alloy one is removed. A small secrion is left at the rear as the alliy cap is structural ro strengthen the roof when the hole is cut out for the elevating roof. The plastic cap then fits over the remains of the alloy one which explains why it is slightly higher than the original. The problems arise because they seem incapable of sealing the plastic cap. Hence the leaks and wind noise. I've said numerous times that IMO its best to get a decent body shop to deal with it. OK you will have to pay but your van wont leak like a sponge and have to go back four times like ours. No way would we buy another Cali because the design is still the same.
This is the repair kit, apart from the paintwork (which VW refuses to do on mine because of too old).
New rubber for the roof, roll of plastic tape for the roof edges, 2 stickers for the front spoiler.
The touch up pencil is an extra, not included in the package.
How old is your Cali? Mine is 2010 and has gone in this week to have the roof edge corrosion repainted and the repair kit fitted under the recall, I did report it last August so it's taken a while!
I'll report back on how it goes later, estimated 2-3 weeks to complete the repair.
@TripleBee , when did you registred your Cali for the corrosion problem . If i recall correct it needed to be done before a certain age . Then time could go over until the actual repair but once registred within time VW repaired every roof .
What dealer was it you used , did you try a other (decent) one ?
Now VW sold you the rubber,ect you could do it yourself or look for a decent body shop. Alltough i personal would not let just any bodyshop/garage toutch my Cali (personal choice)?
VW does only sand the edges down and respay for the moment , apply tape and new seal , now you have those you can dicide yourself . You even could just leave things as they are if not that worse and deal with it over time .
There's noting structrural wrong with the roof .
What did they charged you for the seal and tape?
EDIT : i read in a other thread you did not pay for it , strange they just gave it to you ...
I think they just are trying to hold you of ...first say they don't repair it becose to old then giving you the repair kit ...strange .
They didn't sell this to me.
VW doesn't apply the repair to vans older than 7 years. The dealer can only claim the parts to VW, but not the corrosion treatment, because my van reaches 11 years.
Any other dealer will give me the same answer.
Then I told them to give me the parts because I will do it myself.
I will first knock on vw's door (again) and try to find their answer.
My first corrosion repair was done 5 years ago, and now 5 years later it has returned, out of warranty and no coulance anymore...
When we had ours done we were told that originally VW would prepare the roof where it had corroded and bubbled up then respray and fit new rubber seal. However this was obviously costing them a lot of money so when ours was done we were told that they would be taking the paint off down to the metal just up to the top of the rubber seal..They then treat the metal with a preparation that VW had sent them , then actually glue a new seal in place. Which is exactly what they did..It is impossible to move it.. Regardless of whether this is the method that is used now or not that’s what happened with us 2 years ago. This was done in Sinclairs VW van centre in Gorseinon..Have have taken a close look at the area above the seal to see if anything has started to reappear but I can’t see anything..I’m not bothered if the rubber seal is loose or stuck as long as it looks ok that suits me.
Hé maat, kun je wat informatie delen?
Is that tape that you have from Tesa? Is there a number
on it - like - 51206.
I would use some on my front panel under the rubber if i can get the right one.
Ich wähle immer noch meinen Kumpel selbst :cool:
The tape costs € 22,20 Ohne MwSt at VW, for 8 meters.
The Tesa number is 52994.
The two little pieces for the front spoiler cost €3.10 without VAT each.
But they are specially pre curved.
Please wash your hands very good before applying, because I saw a new California in a showroom once with the tape applied afterwards, and there was a magnificent black fingerprint on the glue side!
Thanks for the tip and the number, there are lots of different tapes
and they all look the same online :thumb
I've no gap between the panels but i thought that the rubber
sat just lipping over the front panel, mine might have done but it
doesn't do now.
My roof corrosion. This is left side just above B pillar.
Next is a small one in the middle -ish
And one part that the roof rubber has worn the paint away, this is
my favourite cos its nice and clean and just straight through to the metal.
Interestingly, all of mine are on the covered up area when the lid is shut.
I've none on the front panel.
The big one.View attachment 65178
Don't know if I have to give this a thumbs up or down.
Up for your post, but down for the amount of damage.
But I have already seen much worse front spoilers. Blistering all over the place above the windscreen.
I have some more corrosion going on on the right rear side:
bottom:
top not so visible on photo, but it's above the rubber from the canvas:
That gap is no defect.
Note, this is a new roof and canvas, but I had some water ingress after the roof change on the rear right side. Coincidence?
