Looking closely at the photo the engineered solution, (tin can) which is a actually a very astute short term remedial, executed well, is set below the fabric edge of the awning so it catches the main water run off from the canopy, presumably the awning front is set higher than the rear fixed point ( attached to the van) therefore the water runs toward the van and finds the path of least resistance and pisses off the side Around the bracket fixing,Isn't PudnBob talking about the gap behind the awning in front of the front mounting bracket? I've not seen a factory seal there only between the two brackets.
Bland better than Bling!Rainbow Pop top cover in stealth grey to go with the grey windscreen cover on our grey Cali! Hopefully not to bland
Did you have towbar prep pre installled from the factory or was this for the whole thing wiring as well? Sounds promising.Westfalia removable towbar, with 7 pin electrics. £400 all-in, inc VAT, from K&M Coachworks in Slough, a long established father-and-son operation.
Now need to look for a reasonable second hand Brian James car trailer on Fleabay. They seem to hold their value even better than Calis.
What a great idea. I’ve been searching for a taller windshield for my Gaz 907 bottle and attached burner for ages. I will now buy 2 and ‘pop rivet’ them together. Thanks.Couldn’t find a wind shield tall enough for our Cadac so bought two short ones and joined them together. Glued and then silver tape over the top for reinforcement. Works well and less than £7. They came in two bags which now fit one over each end.
I don’t think it would fold totally flat if you were to use pop rivets? That’s why I glued and taped it.What a great idea. I’ve been searching for a taller windshield for my Gaz 907 bottle and attached burner for ages. I will now buy 2 and ‘pop rivet’ them together. Thanks.
Get ready for the accusations of watching television to the exclusion of everything else!Ferguson 12v TV and a Chromecast along with a TV Mount for the headrest. View attachment 51198View attachment 51199
Got enough room for them?Just back from a cruise and was delighted to find this magnetic salt and pepper set in Galeries Lafayette. Also a tile diffuser thing from a hippy bloke in Marseille View attachment 51235View attachment 51236
Oh yes, always room for more ‘customisation’Got enough room for them?
I went through the same procedure 5 weeks ago and he told me the same thing. Received my parcel on Tuesday and it fits like a glove and looks great. Tried it out overnight when we had torrential rain and the following morning not a drop of water had touched the actual pop top canvas. Well pleased.
Update on mine; just had 4 nights in the Lake District with the pop top screen in situ. The heat retention inside the Cali greatly improved and the almost total blackout in the morning is excellent and makes for a good lie in if you want one.That’s great to know. I drove hundreds of miles just to have the chap measure it all for me. I was useless doing it myself. Should be getting ours in the next few weeks!
