Sp0_0k
- Messages
- 1,247
- Vehicle
- T6 Beach 4Motion
My main concern is about beach version.
There is no need to put a mains cable through the window on a T5 SE Cali.
I can't speak for European Cali specifications, but the UK T5 version SE has a mains socket on the end of the kitchen unit behind the passenger seat (driver's seat in your case) which is only powered when the hook up is plugged into the campsite supply.
We also have a 2 pin 230v 150watt inverter socket, driven off the leisure batteries, low down on the on the 'B' pillar also behind the passenger (driver's)seat.
I am guessing that the 'B' pillar inverter socket is still fitted on the T6 Ocean and the mains powered socket is also available. This mains socket will clearly differ in design in Europe to the UK 13amp 3pin spec.
Alan
My Cali UK spec RHD has a european mains outlet socket as standard.
John
Did you specify that option? I don't think it is a standard one in the UK.
Alan
Alan
According to details in configurator that price includes not just inverter but outside socket connection and possibility to charge the leisure battery from outside power. Which now seems as logical cost.
No. The outside socket is for plugging the mains lead from the campsite Mains supply into the vehicle. That mains supply then provides mains power to a socket in the vehicle and also to a battery charger to charge the built in Leisure battery. You could plug an extension lead into the internal mains socket to provide power in the awning.Forgive me if I'm being naive here (useless with electrics) but does this mean there would be a standard 3 pin socket accessible on the outside of the Cali? The kind of thing we could plug a microwave into in a drive away awning? Way too much hassle on the short trips but for week long stays in school holidays this would be a real treat - my parents had this with their caravan last summer and it made life very convenient!
Hi, which slow cooker do you use? Do you know its wattage?Runs my slow cooker, smells great when your driving!
On hookup it gives 220V direct from current power and one can use higher wattage.
At least on a SE don't know Beach....
If not on hookup the 12v to 220v inverter indeed can only be used with 150w accecoires...
I think a must have , thats is why they now offer it on the Beach , this was a missing option on the older Beaches
Or you could run the hook up lead into the awning then use a splitter. One lead to the hook up socket on the outside of the van and one lead to a normal three pin 13amp. socket for use in the awning.Forgive me if I'm being naive here (useless with electrics) but does this mean there would be a standard 3 pin socket accessible on the outside of the Cali? The kind of thing we could plug a microwave into in a drive away awning? Way too much hassle on the short trips but for week long stays in school holidays this would be a real treat - my parents had this with their caravan last summer and it made life very convenient!
If it's any help ... The 2 pin in my T5 seems to be the standard European socket. It had me puzzled for a while when I was trying to plug my electric shaver into it.... Apparently these are not the same.Can anyone please confirm whether the "2 pin" inverter plug in an Ocean is just a standard mainland-EU plug, or whether it is different?
I only ask as I have a UK four-plug with an EU plug on the lead already. I'm guessing I would only use the inverter for laptop charging (85W) but may well find other uses yet....
Thanks.
Which slow cooker is that?Runs my slow cooker, smells great when your driving!
We have one too.I use this in the Inverter socket. Works very well. 7w power requirement.
http://www.+amazon+amazon+amazon+amazon+amazon+amazon.co.uk/gp/product/B000WZO0EA?keywords=insect repellent&qid=1448307793&ref_=sr_1_8&sr=8-8
