Nottledim
I think I have added too much adblue to the adblue tank and the dashboard still says I need to add adblue. Do I just wait till the level drops or have I broken the level monitor?
Why do you think you have added too much?I think I have added too much adblue to the adblue tank and the dashboard still says I need to add adblue. Do I just wait till the level drops or have I broken the level monitor?
I don't think it resets immediately but after a few miles driving. I cannot confirm as I don't have a T6.The dash said max fill 3.5 litres I added 5 there was no overflow or puddle so I’m sure it all went in
There are reports of them failing on other Adblue vehicles but not many at all on the T6.I’m just concerned that I don’t know the level in the tank if the warning display always says adblue range 1000 miles even when it’s full or over full.
I did the ignition off and on and I have driven about 60 miles so far so yes it’s off to the dealers.
I quite like Hereford.
Valve on the dispenser? I guess you mean at a forecourt. I fill mine up from a 20 litre container with a funnel and judge how much I put in. Dash display updates accordingly. A lot cheaper too.I don't think you have a problem - I always fill mine up until the valve on the dispenser stops the flow - never had a problem.
No I don’t mean a forecourt. I bought a smaller bottle from Halfords that came with a valve based dispenser. I then fill that smaller bottle up from larger 20L containers of Adblue as per your suggestion. That way I get a controlled fill that auto shuts off when it’s full avoiding spillages. Hope that helps!Valve on the dispenser? I guess you mean at a forecourt. I fill mine up from a 20 litre container with a funnel and judge how much I put in. Dash display updates accordingly. A lot cheaper too.
http://www.distribution365.co.uk/pr...fu0ccgIrPGpTDVIbJkfnZ8fK8zKhPOgphEaAkjl8P8HAQ
After filling with adblue you must turn on the ignition and wait a minimum of 30 seconds before starting the engine.I think I have added too much adblue to the adblue tank and the dashboard still says I need to add adblue. Do I just wait till the level drops or have I broken the level monitor?
Yes, helps thanks. I have to confess that when the dash display says fill up with a min and a max numbers of litres I put in approx the mid point by guess work to avoid spillages. Been OK so far! Famous last words!!No I don’t mean a forecourt. I bought a smaller bottle from Halfords that came with a valve based dispenser. I then fill that smaller bottle up from larger 20L containers of Adblue as per your suggestion. That way I get a controlled fill that auto shuts off when it’s full avoiding spillages. Hope that helps!
Filling up at the forecourt is much cheaper.....on average less than 60pplValve on the dispenser? I guess you mean at a forecourt. I fill mine up from a 20 litre container with a funnel and judge how much I put in. Dash display updates accordingly. A lot cheaper too.
6000 miles? Must be code for careful driver!!Just filled up today 14l cost free. Chap said he take payment next time. For the first time it's showing as 6000 miles. It's always shown a max of 4500 miles before.
Thanks for tip.Filling up at the forecourt is much cheaper.....on average less than 60ppl
