s2bear
Hi all, had B14s fitted to my Beach today. As I understood it, the ride height is adjustable through a range of -40mm to -70mm vs stock. I asked the garage to lower it as little as possible in that range and naturally expected this to be -40mm.
My reason for this is I think that 30-40mm lower still looks good and is a practical compromise between stock and mowing the lawn with my car.
So, It comes out of the workshop -70mm and the technicians (who do LOADS of these - they had a shop full of T6s) insist they adjusted the coil overs for the minimum drop possible. They said they left only few threads showing at the top of the coilover and they did this as they’ve previously experienced the spring having some unwanted free movement when the setup is at the minimum limits.
1. I’m slightly miffed / disappointed by the result.
2. I look a bit like a clown who just won some cash and went straight down to Halfords.
I’m still on the 17” Cascavels until my new rims arrive and obviously things will look better when they’re on.
Has anyone else fitted B14s and achieved a lesser drop than -70mm?
The Handling has improved dramatically whilst the ride is noticeably firmer and akin to GTi levels of tautness rather than bone shaking. However, I don’t want a 70mm drop - I went with B14s as I wanted the best ride and -40mm. Ho hum!
