HELP!!!! Rear seat won't lay flat
caz5306
Lytham St Annes
T5 SE 180
hi. We have a 2015 Cali and the rear seat will not lay flat to make the bed. We've tried everything we can think of. We pull the strap, headrests are down, it clicks but is stuck solid. We've never had this problem before and are at a loss. We'd be very grateful for help and suggestions. Thanks very much
Welcome on your first post .
Diffrent things can be the cause , reading some the existing topics using the search function can give some tips.
I assume you are not new to using a Cali and have used the bottom bed in the past.
My only thought is if the seat belts are tight, that can prevent the seat back from going flat. Before you push the back down, pull out a short length of the belt each side.
The locks each side are controlled by Beldon cables. It is possible one of these had broken, if so a visit to your Cali specialist dealer is required.
Alan
Not been back since Sunday so obviously sorted.:cool:
Alan
Thanks Alan. Apologies for late reply but signal was intermittent in France. We tried everything but drew a blank. We are back in the UK, just, so will book it in with our local dealer asap. Thanks again
Sorry our signal was intermittent in France. Tried everything we could think of but drew a blank. We will take it to local dealership later this week to get sorted. Many thanks for replying
