Yes, it all works perfectly.did your set up in post #96 work OK?
Yes, I got one of those.would this be OK? from Amazon. £11.99 all made up
I've just recently thrown out the invoice!if so might you be willing to let me know the exact parts you ordered & where from so I can copy?
Just checking out the Dometic lead and noticed that the cigarette lighter end is actually a 12v plug/socket combo.
Is this a standard fitment ? I couldn’t find on google etc. If so could be a neat alternative to Anderson connectors.
Note there is a 10amp fuse in the bit that goes into cigarette socket
The cable is about 2m long and is rated at 16AWG , 1.31mm^2
Hi @Amarillo --- might it be at all possible for a photograph please?
Of the left side of your passenger seat where the wire comes out.
Hi @Amarillo
Thanks ever so much for that, that's really appreciated-- & is it straightforward to push the red & black lead under the metal seat box thing? Looks like you've not had to drill anything. I'm getting a solar panel fitted, so was thinking of doing this all at the same time.
Also, is the fuse outside or inside the seat box?
The ready made battery ring to Anderson lead is not long enough, but attached to the battery ring to Anderson is an Anderson to double Anderson adaptor.I understand now -- thanks -- was your cable long enough to have the Anderson connector on the outside? Did you choose to have the connector behind the plastic hatch for a particular reason or wasn't it long enough?
I'm thinking that having the Anderson on the outside as that would be more flexible as I could connect directly via Dometic lead when fridge inside (behind front seat most likely) but attach a longer extension cable when fridge outside in a tent)
thanks and sorry for all the questions
I would have thought that 500mm would be plenty to poke out from under the plastic hatch. You could check with a bit of string.That looks really professional, thanks. Similar child proofing needs here, although I think mine are older than the ones in your pictures! (10yrs and 7 1/2yrs)
I could, of course make up a longer battery ring to Anderson connector cable -- have you an idea of what length cable would be better ? & I'll get it made up
(the one in your photo is 300mm long, the amazon one 500mm long)
Thanks ever so much for all your advice with this!
I think this is the master thread for hard wiring a fridge in a California so I am resurrecting with some questions.
Thanks in advance!
- Why is there a need to have a big 40A fuse in the wire when you could have a 10A which would help protect the fridge as well? I read somewhere that someone had put a big fuse and a little fuse, seemed pointless but I am not an electronics expert.
- Does anyone know the terminal stud size on a T6.1 Beach under-seat leisure battery? My Van is not to hand and need to order the right terminals. I assume it is 8mm because that is what has been mentioned on these threads.
- Does anyone know the cable size of the Dometic cable for the CFX3 25 fridge? Does it crimp/solder into the 6mm Anderson studs ok?
The big 40 amp fuse is probably supplied to cover ALL eventualities upto the maximum of the Anderson connectors and wiring supplied. After all the manufacturer has no idea what the purchaser is going to use it for. If you are only going to use it for the fridge then a lower rated fuse could be substituted. If used to power multiple items then fuse each individual appliance lead appropriately upto a maximum total of 40 amps, or whatever the large fuse supplied is rated.The big fuse is to protect the battery, the smaller fuses for each appliance.
But you are right, there is probably not a need for the great big fuse at the battery end of the wiring a small fuse could do. Just work out what the maximum current you might draw out of the battery.
But just think what the battery might do to your California if rodents chewed through an unfused cable.
Big fuse close to the battery, appropriate fuse close to each appliance.
In answer to your question Yes. The -tve lead should be moved to a Chassis ground/earth point.So I finallly managed to get all the bits and bobs and hardwire my fridge. For reference I have a T6.1 Beach. I bought the following all from https://www.altecautomotive.co.uk :
1 x standard blade fuse holder with 100mm of 4mm2 wire coming out of each end.
Some 4mm squared cable to build the negative side and extend the fuse cable.
6mm ring terminals (this is the size needed for the beach).
Twin automotive cable 4.5mm2
5 x Anderson SB50 connectors.
Some boots for the connectors.
1 pair of 10mm2 pins for the Anderson connector.
4 pairs of 6mm2 pins for the Anderson connectors.
I have two fridge locations, one behind the drivers seat (I have a LH drive) and one next to my 2 seat bench. I wanted to have an Anderson connector at each location.
I have the fuse between the battery positive (there was a free threaded stud on the positive terminal, see picture) and the first Anderson, and currently the negative wire going to the negative on the battery. I then wired up two extensions (one short for behind the seat and one long to mid ships) into 1 Anderson that plugs into the one connected to the battery. I cut the Dometic cable quite close to the fridge plug and crimped on an Anderson.
Some things of note:
So far it seems to have solved the problems I had, great. However, I have one question to do with the location of the negative connection. I have read that with the T6.1s, when you wire up solar, you must connect the negative to the ground (usually the bolt the holds the small battery clamp) rather than directly to the battery. If you connect to the battery it can confused the control panel? My setup is currently working connected directly to the battery but when the fridge compressor is running, it no longer shows amp draw on the control panel. Do I need to change the negative location to the earth? Am I risking some sort of battery error on the control panel?
- I could not find a smaller Anderson pin than for 6mm2 cable. It seems to crimp securely to 4mm2 and even the 1.5-2mm2 cable from the dometic fridge. I just stripped off a longer but of outer cable and twisted into around to make a bigger bundle to fill up the crimp volume.
- The 10mm2 Anderson pin seems perfect for the 2 x 4.5mm2 cable that goes into it.
- The Anderson pins are not that easy to crimp. I borrowed a friends cheap ratchet crimping tool (with large jaws) and it seemed quite on the limit but did work.
- I tried to connect to the battery at both threads of the main clamps. It was impossible to attached the positive due to access and a damaged thread. I have to remove the seat to gain full access to the positive terminal "cluster". This was easy, 4 x 13mm bolts/nuts removed with a socket. Everything from below is captive so no need to worry about losing nuts. I carefully liften the seat up and rested it on the steering wheel. No need to disconnect the seat heater/airbag plug.
Thanks to all those who have contributed to this topic.
