Yes about right.I've recently purchased a 2018 California ocean 4motion with the dsg gearbox and am disappointed because on a 250 mile journey from cumbria down to luton with the cruise set at 70mph I'm only get 32mpg is this correct?
On motorways I generally set the cruise control to 58 mph, this helps economy, keeps HGVs from overtaking, and allows me sufficient acceleration to pass slower vehicles while keeping within legal limits. I also find the drive more relaxing and therefore more enjoyable.I've recently purchased a 2018 California ocean 4motion with the dsg gearbox and am disappointed because on a 250 mile journey from cumbria down to luton with the cruise set at 70mph I'm only get 32mpg is this correct?
Few HGVs are exempt from having a 56mph speed limiter fitted, so while the de jure limit may be 60mph, the de facto limit is 56mph.But HGVs can travel at 60mph on motorways.
Travelling at 58mph is asking for trouble and in my opinion dangerous on a motorway
This is true. I set the cruise to match the lorries now and fuel economyAs soon as you go over 60 its a steep downward slope in mpg.
I do this too now. The difference in fuel consumption it makes on my petrol Cali is astonishing. It feels much more relaxed with the trucks. I cannot see how it’s less safe for me or anybody else than doing 70, 80 or 90, which I used to do in my car.Few HGVs are exempt from having a 56mph speed limiter fitted, so while the de jure limit may be 60mph, the de facto limit is 56mph.
Tell the lorries on the M4Few HGVs are exempt from having a 56mph speed limiter fitted, so while the de jure limit may be 60mph, the de facto limit is 56mph.
HGV's are limited to 56MPH or 90kph. Legally it is 60 but Tacho registers overspeeding above the 56mph which is or can be used to aid any prosecution. Buses can do 60+mph or 100kph and as they are no longer permitted in 3rd lane of Motorways holding them back isn't either courteous or legal if inner lane is clear.But HGVs can travel at 60mph on motorways.
Have you tried it? Whether 58 mph in the UK or 95 kph in Europe, if you set the cruise control to that speed few HGVs will overtake. A few coaches perhaps, one or two vehicles >3.5 tonnes and <7.5 tonnes but no larger vehicles. You catch them, and with ACC track them until ready to pass.Tell the lorries on the M4![]()
It less safe for one simple reason. In an accident the kinetic energy getting rear ended by 40t at 56mph has a very different outcome than by 2t at 70mph. If your getting a move on your in a lane or near to an escape lane the waggons dont go.This is true. I set the cruise to match the lorries now and fuel economy
The minimum vehicle speed below which it’s considered unsafe is 25mph.It less safe for one simple reason. In an accident the kinetic energy getting rear ended by 40t at 56mph has a very different outcome than by 2t at 70mph. If your getting a move on your in a lane or near to an escape lane the waggons dont go.
If was going to go 60 on a motorway I would go back to a caravan.
Single track roads you dont have a choice. We are talking motorways are we not.The minimum vehicle speed below which it’s considered unsafe is 25mph.
What do you do on single lane A roads?
Rear ending by lorries tends to happen on motorways when traffic is stationary. Do you remain in the outside lane in stationary traffic too?
The kinetic energy of hitting something yourself is higher if you are going faster, and you have less time to react to hazards. Its bleeding obvious.
It’s not the ‘fast lane’ it’s the outside lane.Single track roads you dont have a choice. We are talking motorways are we not.
Rear ending happens when you stop and the waggon behind doesnt. This is even worse , a sandwich. Yes I would be in either the middle or fast lane preparing for a potential accident.
Clearly its not bleeding obvious. This is nothing to do with before an accident rather what happens when you have an accident.
Its not as simple as speed so bleeding obvious neither momentum or conservation of momentum has been understood.
We are talking consequence not risk. Your referring to before the accident , Im referring to after the accident (event), classic Bowtie hazard analysis.
The middle lane means you have access to the inside or outside lane and no waggons in the outside lane. If your in the inside lane your boxed in for sure.
It really is obvious that getting hit by a car and sandwiched to a car in front of you at 70 mph is preferable to being shoved by a 40 tonner at 56 mph and sandwiched between another 40 tonner.
It could be more obvious it appears
So what I say stands mixing it with the heavy boys isnt as safe as with the faster lightweights in the outside lane. No problem straightening this out on the internet. Await reply![]()
