Ah, maybe the English humour didn't translate well.don't get to over the top..there are worser things...
Well, that's not the worst of it, Hotel California.
Have a look at this...
Yes, that's right, I found a moulding fault on both of my keys for the water filler cap!
Typical poor quality control from VW !!
I'm thinking of getting on to the dealer and rejecting the entire vehicle!!!
[Sits down with cup of tea while the entire forum membership goes off to check their keys...]
probably the same trim panelGot it on 2017 model.
Looks like there was life in the old tool! My 2013 has the scar.This was very common on the last run of T5's believe it was the tooling at the factory coming towards the end of its life.
In what way is it a problem?my 69 plate has it, wonder if the T6.1 will have the same problem.
It will be when I sell it.It's a Styling Detail.
If not, sure it will be available as a retro fit, Brandrup are probably costing already.my 69 plate has it, wonder if the T6.1 will have the same problem.
Normal. My 2014 SE has it.My December 2019 registered Ocean has this feature. The vehicle was pre registered by the dealer and I purchased it in February 2020. I didn't notice this moulding fault for a couple of weeks, and when I first noticed it, due to the lighting, it looked like a crack in the plastic.
I have raised the issue with the supplying dealer, who claim never to have seen the fault previously. Is there a solution, or will all supplies of this B pillar moulding have the same flaw because they have all been produced using the same tooling.
If you aint got the moulding fault it aint a real CaliMy December 2019 registered Ocean has this feature. The vehicle was pre registered by the dealer and I purchased it in February 2020. I didn't notice this moulding fault for a couple of weeks, and when I first noticed it, due to the lighting, it looked like a crack in the plastic.
