Skootyalan
Does anyone have any advice on the best levelling chocks for a California Ocean? Is there any difference in the products available?
We choose not to buy any and have never needed any in 18 months of vehicle use.Does anyone have any advice on the best levelling chocks for a California Ocean? Is there any difference in the products available?
Yes.Doesnt the new Cali come with a level guide now ?!
If the vans full Elly?We just have 2 of the wedge type and keep them separate so they can be pushed in to gaps if the van's full at the back.
We camp at a lot of different places and are quite often on uneven ground. They're invaluable to ensure a comfy nights sleep.
I don't think it matters much what type you have as long as they're robust.
I had a small magnetic spirit level which lived in the pocket on the side of the drivers door which I placed on the sliding door step trim, worked for us. (didn't need to magnetic but that's what they had in the £ shop)All Cali's come with a level guide/mesure .
Pour some water in the sink ....
I use the sliding door to check if we are parked up having the front a bit higher than the rear for good night sleeping.
Placing a (transparant) bottle water on the kitchentop is also a good indicator.
On-topic : we carry level chocks since day one and use them frequent.
That is we do use free aires , small campsites frequent and there not all pitches are perfect flat.
If you tend to vistit large 4* campsites your pitch will be level to start with.
Not sure what vehicle you have, but if you are waiting for a 6.1 there is a built in level.Does anyone have any advice on the best levelling chocks for a California Ocean? Is there any difference in the products available?
The built in level only tells you if your level you would still require something to drive the vehicle on to to actually level it.Not sure what vehicle you have, but if you are waiting for a 6.1 there is a built in level.
I worked that bit out! But we just move the van slightly until perfectly level. Drives the Mrs nuts! Which is why I do it.The built in level only tells you if your level you would still require something to drive the vehicle on to to actually level it.![]()
Sorry, the way it read was the van self levelled but could be me with a Saturday morning foggy head, I know you have lots of Cali experience which is why i was surprised.I worked that bit out! But we just move the van slightly until perfectly level. Drives the Mrs nuts! Which is why I do it.
We’ve got Milenco ones and use them a lot. Good thing about them is that they have ‘shaped‘ steps In them meaning that you don’t need chocks to stop rolling back.
