andyinluton
- Messages
- 7,661
- Vehicle
- T6.1 Ocean 204 4 motion
The tools are for fixing kids bikes predominantly, other than fuses & bulbs there’s not a lot On the van that I would bother attempting to fix.
Wow there are some seriously prepared Cali drivers on here. I hope I am parked next to you when I get in trouble lol.
I once saw this thread title on a Millwall FC forum, the answers were somewhat different though.
I have that problem, even when wearing a head torch.Several torches never know where I left them.
Blimey, do you plan to re-wire the dashboard while you're out on a camping trip?American bojo professional trim tools and a wera socket driver set. The wera set is small in a soft case. Very special wrench that converts to a driver, again quality. Need to add a set of thin nose pliers FFX top tool supplier
I have a trip to Iceland planned for later in the yearBlimey, do you plan to re-wire the dashboard while you're out on a camping trip?
For me, anything that reduces the payload capacity for essential supplies (beer outbound, chateau-bottled wine inbound) isn't getting a space. Basic tyre-changing gear etc and an adjustable spanner etc in the van (and a Leatherman like Borris's) but I work on the basis that for anything else there will be a garage along the route that can provide and wield any other tools needed.
(Serious 'overlanding' would be different of course but haven't done that in the Cali.)
Good philosophyBlimey, do you plan to re-wire the dashboard while you're out on a camping trip?
That’s about as much as I carry. If it needs anymore than that it’s a recovery job or wait until I get home.I carry a large breaker bar and socket for the wheels. Under the drivers seat I use tupperware with a lid. It usually has pliers, Allen keys, cable ties and other odd bits. More for fixing random jobs and bikes than anything major.
It's a good approach and having those in the van means (sods law) your neither your aux belt nor EGR pipe will EVER fail on a trip.I carry lots of the above, but I also carry;
Spare Aux belt
Rear EGR flex pipe
Silicone pipe repair tape.
I carry the belt and pipe so that if I have a breakdown and call VW assist, He can swap these parts for me instead of having to be referred to a dealer.
Not if they are set to the correct torque settingNever had any problems getting a wheel off using the VW tool.
They are.Not if they are set to the correct torque setting![]()
Please park next to me so that I can (try, and) use my tools on your van (and learn how to use them)Wow there are some seriously prepared Cali drivers on here. I hope I am parked next to you when I get in trouble lol.
I've had problems with the VW tool. Combination of poor (loose) fit on the nuts and the general angling of the wheel brace. Right pita.Not if they are set to the correct torque setting![]()
If they're wearing tights. Think leggings would be too bulky.As far as I'm concerned the days of the DIY roadside fix on the modern car are long gone hence my minimal tools list. Unless its changing a wheel or a bulb, your chances of seeing the problem let alone getting to it are at best, remote. So if it's broken or flashing there are usually only two courses of action:
1. Switch the ignition off, wait a while, switch it back on. If it still doesn't work....
2. Call VW Assist or the AA etc.
If it's smoking, on fire or haemorrhaging fluid of any kind then there's a good chance it's buggered. Besides our roads aren't as quiet as when Mr Toad was a keen young motorist. With todays busy roads you will be risking life and limb doing any sort of road side fix.
Anyway I don't think asking a lady to remove her tights in order to replace a broken auxiliary belt would be considered PC these days that's if you could actually get anywhere near it without removing the front of the car.
I don't understand, why do you need to remove parts of the car to get at whatever your lady friend has (ahemAnyway I don't think asking a lady to remove her tights in order to replace a broken auxiliary belt would be considered PC these days that's if you could actually get anywhere near it without removing the front of the car.
If you are driving to Europe then forget the long life milk till you get to Aldi’s on the other side as it’s now banned..As @Borris + Longlife milk and teabags.
Agreed, Ive got similar + a can of the gunge as well as a spare wheel.One of these, changing a wheel is a PITA and this can usually get you to a garage or at least a safer spot to change the wheel.
Tyre Inflators, Pressure Gauges & Pumps | Halfords UK
Get your car tyre pressure spot on before leaving home. Shop leading brand digital tyre inflators, pressure gauges and emergency repair kits here.www.halfords.com
+1. They are a good get-you-home if you have a slow puncture.Agreed, Ive got similar + a can of the gunge as well as a spare wheel.
