Nice!Fitted Hexlox bolts to the bike rack. Quicker & easier than I expected!
Such a simple concept for peace of mind.
Nice!
What was the final verdict on sizing? I know there was lots of discussion, and keen to nab them myself (the bolts - not your rack! )
What kind of additional costs can we expect on something like this in terms of VAT or import tax. The site makes no mention of it. Any insight would be greatShoe Box by Bus-Boxx
I've sen a couple of posts about similar products although quite expensive. I also recall someone has made their own version. This product looks pretty good and the price isn't as eye watering as others. I did purchase a washing line from Bus-Boxx last year which was really well made, therefore...vwcaliforniaclub.com
Got a bin.
Got a bin.
Did you have to pay any additional VAT or import duties on the bin .. presume you got it from HollandGot a bin.
Sorry, the two M6 x 50mm, thread 1.0 , are just two regular bolts from the hardware store right ?M6 x 50mm bolt, thread 1.0.
Pan head to avoid someone trying to remove the bolt with pliers.
I used stainless bolts to avoid any rusting issues. Just make sure the bolts are threaded all the way up the shank.
4mm hex socket, so 4mm Hexlox required.
I didn’t need to even open the tailgate to remove and replace the bolts.
Certainly worth it if you’re keeping your rack on the van!
I think so, on the invoice it shows:Did you have to pay any additional VAT or import duties on the bin .. presume you got it from Holland
Looks amazing but how much weight is that on the back of the van....Fitted it today, and it all fits as intended! Huzzah, it's not being returned!
When can you ever have too much space (or bikes?)
So the kit you bought it's for 1 key + 2 hexlox 4mm, i.e. this one : https://hexlox.com/collections/single-hexlox/products/universal-hex-bolt-security
Thank for the tip btw, I'm always worried about the rack... disappearing..
Well tow bar is allowed 100 kg & bike rack 60kg? Nothing in the manual about not using both at the same time. The weight is pretty close to the back axle so not huge leverage. Just need to keep an eye on the overall weight on the back axle.Looks amazing but how much weight is that on the back of the van....
Fully loaded both racks with a 199 fwd, it's screaming burnouts!Looks amazing but how much weight is that on the back of the van....
All within nose weight limits.Looks amazing but how much weight is that on the back of the van....
It is very good provided you use it in an upright position. If you tip it too much from the vertical you risk water getting into the fan, and water leaking out everywhere.Not specifically bought for the van but I can see it coming in handy. Karcher window vac.
Looks very nice and offers more options for more cargo. Did you look into reverse camera solution when the box is in use already?Fitted it today, and it all fits as intended! Huzzah, it's not being returned!
Don't leave that in place for longer than required. It will stick to and can spoil the paintPreparing for travel, hopefully not wishful thinking.
Stickers ?Bought the chopping board that fits in the sink from the Club Shop. Expensive but custom fit is good and provides a bit more worksurface. Put my Club stickers on the van.
