Recommendations for fridge for 2 seater Beach please
it'd be good to know - I quite fancy one of those. are you still out there @gareth230380 ?
Hi, do you still have the CDF 11? I'm in Leeds and would be keen to take it off your hands if you do. Thanks Rachael
Sorry someone else beat you too it. It's gone now.
Sent from my Pixel 4a using Tapatalk
Used a Waeco/Dometic CF11 for a number of years on GB-Greece-GB trips. Will chill even in 40C+ temperature. Use EHU whenever possible to save leisure battery, but no difficulty when doing a long day's run. Holds enough beer for 5pm, cold meats and milk for other times. Stowed just inside side door for easy access at supermarkets and early evening refreshment.
I have a 2 seater beach and after 5 months of use i can strongly recommend the Alpicool c25,it fits perfectly underneath the MFB and its super quiet and efficient, i would say even better than a Dometic i used to have, for the price its really a no brainer
Another vote for the Dometic CF11. Used for a number of years on Greek camp sites. Maintains chilled beers even in 40+ degrees outside temperature. Beware chillers which keep 20 degrees below ambient temperature - not much use with 30 - 40 degrees more frequently with global warming.
Not the best photos but here’s the TB41 and fits fine where you suggest, just have to move the seat forward a tadge or wind the back up a bit to lift the lid fully.
Almost the same height for that L shaped lounge!
View attachment 41601 View attachment 41602 View attachment 41603 View attachment 41604 View attachment 41605
Hi, this fits really nice, but what about the heat coming from the fridge vent? There is no free space for the heat coming out, as the vent seems to be completly blocked. Has this ever been a problem?
Hello everyone. I am a new owner of the Beach Camper T6.1 - 2 seater bench and a storage box. I would like to put the fridge behind the drivers seat (left side seat, I have a LHD car as I am not based in UK). I have several requirements for the fridge, but I still havent found any fridge, which would cover all od them. Maybe it is not possible and maybe some of my requirements are not necesary - I am not sure - please correct me if you think that some requirements are wrong, all of you have definitely more cali using experience than me.
The requirements are:
1/ the fridge should fit behind the drivers seat, just between the seat and the storage box
2/ the fridge should be mountable somehow to something, to be stable not only during during a drive and even a possible accident (a loose fridge could be a weapon in this case) - the best solution would be to mount it to the floor, but most cheaper fridges dont have the option without a lot of DIY work (and the mounting solution should have at least a decent look - I have not bought such an expensive car to have something ugly inside)
3/ the fridge should be able to fit in the back under the multiflex board as well, which is lower than in 3 seater beach
4/ capacity 25-35 litres
5/ the fridge should not be to wide (or long? - sorry I am not a native speaker) - not to reach to much in the second half to the passanger seat (so about 60 cm long max, ideally about 50) - this his more difficult than in a 3 seater because od the gas bottle storage, which takes some space at the wall behind the driver
6/ there should be some space around the vents od the fridge to enable the hot air to come out
Do you have some advice for me? I have checked most od the fridges discussed here, but none completes all requirements, so I will maybe need to cancel some od them.
Photo of my interior - the fridge should fit where the trash bin is
