KGCali
Retired and still young at heart!
Yes, but first try just opening the waste tap and pour a kettle of hot water down the sink, get someone to watch if it drains out in front of the rear wheel. If it doesn't, or is very slow, then put a hose up the outside drain pipe and slowly turn on the hose water to see if it clears the drain pipe blockage.so am I correct in saying, If i leave the drain tap for the tank open all the time, thinking when i drain the sink it will just flow directly into and out of the tank, but if the outlet is blocked the sink will not drain ? So if i close the drain tap the sink waist will fill up the tank with flow, and when i empty the tank when full , i open the tap and it should empty all be it slow or not at all ??
