Y
yossarian
Propane has 4X the pressure of butane, so unless a container is specifically stamped denoting propane capability I would be loathe to use it. The butane (blue) 907 bottle than came with my Cali feels to be of lighter material than my propane bottles. The valve is obviously a different system and spec.
The ratio is about 2.25 at 100C. Less at higher temperatures. The ratio at max design temperature is of interest. Obviously the ratio in Butane's unusable range -5C to -40C will be very high but the pressure much lower.
