I can save you 50% - VW state you should only fit chains to the front wheels. You need half the amount!Will be needing snow chains for my Ocean for trip to the Alps next week.
Has anyone on the chat bought any recently?
Size needed is 255 45 R18, the cost for 4 is pretty expensive!
Hi, I tried buying some and Autosocks said they were sold out for the season. Found quite a few sets on eBay, as new and unused at less than half the cost.I don’t think you can fit ordinary chains to that wheel size, insufficient clearance on the inside of the rim. You’ll need something like K-Summit which fit over the top of the tyre and don’t extend over the inside; but make sure you’re sitting down when you see the cost.
Make sure that you have a trial fitting run. Nothing worse than trying to work out the fitting while kneeling in snow in the dark.So now we have them......I'm hoping I won't need them!!
Have you fitted and used the xg12 Pro on your 255/45R18 tyres yet? I'm about to buy a van with that size tyres and already have the correctHad to buy the the Thule/ Konig XG12 Pro.
In addition to the tyre size the weight also has a big bearing on what's suitable and as the Cali is a little heavy I needed the XG12 Pro which was just a little under £200. The other bit of useful info is the chain size, the options are 9mm 12mm or 16mm, I was advised by a very helpful guy at Snowchains.com that for the California you need 12mm as 16mm would potentially restrict you in achieving a full lock.
