ArunAlec
The sealant is the black strip running around the outer edge of the panel in @Defender90 s photo. I decided that rather than disturb the panel I would try to stop the water getting in, so tightened up the window rubber seal with a short length of nylon cord as in my post above. So far it seems to have worked.Interesting. I wonder where the sealant is applied, can anyone advise?
To access this, am I right in thinking that it's a drill out rivets job, with replacement on completion? Not to mention door card removal and fiddling with the door lock mechanism to remove the window carrier?
I'll be interested to hear in due course if the remedy is successful.
I think the panel is bolted in place, not rivited.
