I had this problem on my Ocean. If you knew that the oil level was ok you have to ask yourself how does the oil level rise? It's not due to more oil coming from somewhere. It's probably due to Adblue and or fueling problems. The way I understood it ( and I know other manufacturers have had similar issues) during regeneration extra fuel is used to get the heat into the dpf to burn off the spot. If the Regen is cut short by perhaps switching off the engine. Unburnt fuel can be injected into the cylinders. This unburnt fuel can get past the pistons and into the sump. If you do lots of short journeys this could happen a lot. It not only raises the apparent oil level it also degrades (waters down) the oil. I think mine was worse because of a faulty sensor. If it happens a lot you need to replace the oil completely. I think there have been some software updates. Whenever you get the chance, on a motorway, drop it down a gear and try and keep above 2000 rpm to get the exhaust temperatures up. Keeps the dpf clear. The Germans are lucky. They they have Autobahns to let rip on! I may not have explained this too well and there may be some other, more technical reasons, but just think that if the oil level is rising it's not extra oil it's probably fuel.
