Good stuff. Used to use it for the roof leaks on my Series 3 Defenders. The only vehicle I know of that had an OFFICIAL Manufacturers Leak Manual.
Hi all, I got a bit of advice from a chap at Toolstation today for waterproofing rivets etc. it is used for boats but also perfect for camper vans apparently. Not sure if anyone has tried it yet. It’s Captain Tolley’s Creeping Crack Cure.
https://captaintolley.com/
I certainly plan to give it a go.
So here is an update to the leaking roof saga. First and foremost a huge thank you to all who have contributed here. The explanation of potential areas of ingress and how to resolve was so helpful. I couldn’t have believed so much water was finding its way through possibly the rivets or the silicon plugs in the roof channels.
Overall steps taken over a period of time were:
1) change roof seal and clean water drains at four corners (but water was also coming in when roof open so clearly not just this problem)
2) use creeping crack cure (bought online from official website) to waterproof rivets
3) replace silicon under plastic covers in roof rails.
This morning after 2 days with some heavy outbursts of rain I checked the roof and it was dry!!!! For the first time in a long time. So pleased. Last week water began to seep in above the passenger window trim as well as corner of roof so I was getting more and more concerned. That has stopped too.
Overall thrilled and thankful that this forum exists! I have found no resolution from dealers official or otherwise.
One thing that I still don’t quite understand id that when syringing water down one of the drains, water was dripping into the driver footwell. I could see it coming from a junction just above the plastic trim next to wheel arch. However it may have been due to pressure as it does not seem to have come in during the rainfall. Any thoughts?
I think that junction is one put in during a visit to my garage when trying to resolve the leak. They said that the tube from the drain going into the wheel arch was really tight, almost off, so put an extension on it. I think I’ve read about this somewhere on another post.
Hopefully I will be dry for a while. A shout out to Steeble, Welshgas and Lambeth Cali for their support.
