L
Lakes_Puma
Does anyone know what current output the rear 12v socket can provide?
Also which battery does it run from?
It runs from the leisure batteries only and is rated at 120w.Does anyone know what current output the rear 12v socket can provide?
Cheers, I’ve just bought an Anker Solix so was interested for that.It runs from the leisure batteries only and is rated at 120w.
Apparently not to be run at full capacity for longer than 10 minutes. I have an EcoFlow plugged in and running at 100w for longer than 10 minutes without any issues yet.
It will work perfectly for that.Cheers, I’ve just bought an Anker Solix so was interested for that.
Mine all run although I tend to put the vehicle in camping mode. By the way you have one in the right sliding door pocket, one in the right side window and one in the kitchen and one in the rear cabinet.Hi, a bit off topic but still on rear sockets. Non of the 3 usb c rear sockets on my van are giving power when parked, surely they should be running off the leisure battery, is there a setting I’m missing???
There is a setting on the rear screen to enable rear powerCheers for the info, I have tried all 3, non are working
I don’t have that option!
Thanks for that, works perfectly, and I’ve just discovered the California van life app for the other functions I was looking for, Geez that manual is crap, and tbh I think my handover could have been a bit more in depth, so thanks to the boffins, I’m sure they’ll be some more noob questions comingTo get to this menu, I believe you need to press the home button once to wake to screen up - this will take you to a sort of quick menu. If you then press the home button again you should get the full menu. If you select Camping Mode in the full menu, you should see the options Ian has highlighted above.
Hope that helps!
