Andy
mountainman said:My Van has been booked into Benfield Garage North Shields for some 6 months now. It is due for roof corrosion repairs soon I hope. The van is coming up for 3 years old at the end of this month and I want to make sure any other corrosion issues are dealt with at the same time and under guarantee. At present I can only see corrosion on the panel above the windscreen. No corrosion is visible on the roof and I don't feel inclined to peel back the rubber seal to look further as it seems quite firmly fixed.
Should I look further? Have other members found significant corrosion under the seal if it wasn't already visible above?
It will be some time before your van gets sorted, but it will get done eventually.
You really should pull the raising roof seal off as you most likely have bubbling under it. If so you will be able to get this done at the same time as the front panel, but you need to get a separate warranty claim in for it.
