Brandrup ISO-TOP MK VI pop-up roof insulation for the VW T6.1 / T6 California with manual operated pop-up roof with a big front opening
£569.99 Inc VAT
In stock
ISO-TOP is the all-rount talent for seasons in between and summer: Isolates and protects effectively from cooling by wind infiltration – Ideal for temperatures between approx. -5° to +45° C.
ISO-TOP is concipated for the use all year round: An isolating air cushion is created between the gaiter and the ISO-TOP, which is also effective in high temperatures – also in midsummer it is noticeably cooler under the roof. When the windows are opened, a refreshing air current is achieved and the double wall (gaiter + ISOTOP) dams the heat.
If it is cold, the warm air from the parking heater is not “blown away” through the gaiter.
ISO-TOP is always ready for use and remains mounted in the pop-up-top and needn’t to be dismounted. ISO-TOP folds itself away, whenever the pop-up-top is closed.The windows on the side of the ISO-TOP can remain closed when the roof is closed in order to protect the bed from dampness when the roof has to be closed with wet gaiter.
There are big windows with zipper on three of the sides. If there is a bow window in the gaiter, ISO-TOP can also be fixed to the division bar.
The new high-tech material is highly breathable and absolutely windproof. The windbreak, the reduction of dampness, the indoor climate and safety are excellent. The ISO-TOP membrane also protects the bed mattress from humidity, when closing the top with a wet gaiter: additionally to thermal insulation (cold/heat), ISO-TOP offers an efficient protection against humidity and absorbs exterior noise.
The membrane on the reverse side is black to ensure a better sleeping environment.
At the front ISO-TOP is attached with hook-and-loop fastener to five special holding-pads, which have to be permanently fixed to the front interstice of the roof lining.
Above on the sides, ISO-TOP is attached to the existing eyes of the child safety net
Please Note: The front window of the Iso-top must be unzipped when lowering or raising the roof to allow for air flow. Failure to do this may result in damage to the Iso Top or the Bellows of the California.
ISO-TOP MK VI can mostly remain mounted in the pop-up roof: Only the front wall as well as the optional FLYOUT mosquito net have to be taken off before closing the pop-up roof.
Made in Germany.
100 701 072
Brandrup
Brandrup is High-quality campervan accessories Brand for Volkswagen California, Multivan, Caddy, and Mercedes Marco Polos.
Be the first to review “Brandrup ISO-TOP MK VI pop-up roof insulation for the VW T6.1 / T6 California with manual operated pop-up roof with a big front opening”
You may also like…
  • Comfortz VW California ‘Cali-Wrap’ – Thermal Roof Wrap
    Price range: £249.99 through £374.99 Inc VAT
    View product
  • Pop Top Bellows Bungee – Grey
  • Comfortz VW T5 / T6 & T6.1 Thermal Windscreen Cover
    £134.99 Inc VAT
    View product
  • Tear Aid Fabric and Drive Away Awning Repair Kit (Type A) Poptop Repair
    Original price was: £10.49.Current price is: £8.99. Inc VAT
£569.99 Inc VAT
