Amarillo
Tom
It is not the pump design that irks me. It is the tank design. Why not design the tank so that when filled to the correct level the pump will cut out?The Adblue pumps don’t just serve T6s. Doesn’t the pump tell you how much has been dispensed when you hold the trigger. So just release the trigger when the amount you require has been dispensed.![]()
Yes, the MFD gives me a max and min refill quantity, but not being able to use the pump as the pump manufacturer (presumably) intended just makes the refilling that little bit more awkward.
