britlandscape
Whilst I was away on my first trip in my recently acquired GC600 I awoke one morning to noise from the water tank area under the bed, The previous day I had the same problem and just turning the tap on and off stopped the noise. This time it didn't. So early morning searches on the forum said removing the fuse worked which I did but it also stopped the water supply to the bath basin and shower. Also, the water levels in the Control Panel stopped showing the levels. After contacting VW Manchester I have been told that the earliest appointment is 5th December - no water for 6 weeks !!! - what excellent service is that?
Anyway, before I removed the fuse I tried to remove the two drawers under the sink so I could see the tap but I couldn't find a way of releasing them - can they be removed? and if so how?
I would add that before I purchased the vehicle both of these drawers had to be repaired because the laminate on the rear inside face of the drawers had bubbled. That was repaired by VW Swindon by the dealer I bought from but after a month the bubbling has returned. Has anyone else had this problem and if so what is the cause - is it connected with the tap problem?
Many thanks
Many thanks
