Cemswood
- Messages
- 38
- Vehicle
- T5 SE 140
Away at a campsite in Yorks, it's the first time for me and my 11 year old and I've put gas bottle in, connected regulator and think I've turned it on but there's no gas coming through. Starving!!
That red tap opens and closes the water tank drain.Yes thank you I would have if I'd had time. Thanks for the help folks it's now working. I think I may have done something wrong when filling the water though. I only put a bit in at a garage and it's not showing on the indicator and nothing in the tap. Was I supposed to move the red lever next to the gas bottle first? Thanks to people who are patiently replying. I realise it would have been better if I'd had time to try it out first.
If the red lever was in open position the water would have been running out underneeth.... The controlpanel indicator for the watertanks ( fresh and waiste ) are not accurate .... If you fill the fresh water just keep adding until it poors out from above making sure it is full. Are you sure the tap is working ..... Better start all over....first we need to know......is your Cali new or 2nd hand?
It's a brand new t5.
I've had her three weeks. I'm a bit confused about the water, filling up and waste. The manual isn't the greatest and I'm not very tech minded but trying to learn, and determined to do it myself. So if people don't mind explaining it in fairly simple language whilst gritting their teeth and thinking 'why doesn't she read the manual or prepare better' I would really appreciate it
The water tank takes a lot of water before it registers on the display panel. The tap will take a moment to "prime" itself and get the water flowing.I'm a bit confused about the water, filling up and waste
Just remember to turn the gas bottle off at the bottle when you set off so there is no chance of a leak in transit.Thank you both that is really helpful. Will try that tomorrow. I don't think there's any water in it, either that or I just didn't put enough in. I hadn't moved the lever so I wonder if it's default position is open, which seems a bit strange. I'll check tomorrow, we've got bottled water for tonight. I haven't tried the hook up yet, that's for Wednesday. We're having a road trip from Northumberland to Huddersfield, cheating by staying in a hotel in Liverpool then Cornwall then back to Northumberland.
Ok thanksJust remember to turn the gas bottle off at the bottle when you set off so there is no chance of a leak in transit.
