Or a Solar panel setup.Hi there,
Just wondering how folk living in flats charging their leisure batteries? I’m finding it tricky to be honest and I’m told the batteries need a 230v mains hook up at least monthly.
Dave
Drive it
If there is parking near the flats you may find a point you can plug into with some negotiation which is what I did.
Mike
Thanks all. From what I’ve read you’d need to drive a hell of a lot to charge the leisure batteries given most charge will go to the vehicle battery if radio on, ac on etc. I’ll probably just try and plug in for 12hr once a month.
Go to your nearest camp site, bung them a few quid while you hook it up for a day and go walking
Had the same problem. So i was charging a 120Ah (20 Kg) battery in the flat and bringing it down to the Cali , connect an inverter to it, and plug the van into the inverter connected to the battery. Usually the inverter would cut off after 3-4 hrs therefore I had to repeat the process for three to four times, until the display would show 13.1 V with 0.1 A coming in.
It works, but you need invest 400 quid for the extra battery, inverter and charger.
After 8 months I got fed up of bringing up and down the flat the 20 kg Battery and the inverter, although i developed strong biceps in the process.
Now I have a portable, foldable 120w solar panel with the mppt victron 75/15 charger connectet via Anderson plug to the front L battery. the panel is layed on the dash against the windscreen. Now the leisure batteries are topped up once a day with no effort.
Two 50cm long and 6mm^2 thick wires, one for pos+ and one for neg-, with a ring terminal on one side to attach to each pole of the front battery. The other end of the wire both into an Anderson plug SB50. Permanent hot connector. I then connect the mppt victron charger to this terminal.This sounds like a great idea. Was it hard to set up?
My understanding is that driving the T6 only tops the leisure battery(ies) and engine battery to ~80%, regenerative braking tops the engine battery to 100%. Hook-up once a month tops the leisure battery to 100% and keeps that part of the battery going.Driving is all you need to do from my experience so far.
One of my leisure battery is under the left front seat. So all internal.So do you have to leave your window or bonnet open to connect to battery?
Certainly. Of course you can also use it to charge the engine battery, should you ever need that.I like the sounds of that. Don’t need a full solar package and that would take the hassle out of charging up for me.
Mike
