Elmo3
We have the same holes in pretty much the same place. Leaks seem to come from high up but I'm sure it's not helping the situation.New Ocean picked up just over a week ago. 04SA, 13/12/23. Not had chance to use the roof up to now. Noticed a few spots where daylight comes through. This is our 4th Cali, not seen this before. Anyone else observed this on the latest bellows? Seems I need to get it out in some rain…
View attachment 120567View attachment 120568
My 03S does the same as yours.Does anyone with a leaking 04S have a picture from the outside when it’s leaking through to the inside?
Thought I’d join the fun this morning and give my 03S a little workout…as I mentioned I suspect mine may have been treated with a water repellant coating at the dealership as it hasn’t leaked in quite a few tests now. Interested to know if anyone else’s beads water in the same way mine does?
Mine beads much the same as yours - 04S ADoes anyone with a leaking 04S have a picture from the outside when it’s leaking through to the inside?
1 person (6.7%) according the poll. Pretty poor result IMHO, for a revised product that has a simple job to do. This is not rocket science or brain surgery.Anyone had any 4S post 9/11 replacement bellows installed that are preforming ok and don’t leak?
for your Cali just yet. Remember the best relationships take time to forge!Yes they seem to have added black tape in the horizontal seams but not the vertical seams in the 04S. Not all have shown signs of leakage though so definitely an improvement over 03S. To be fair to them most of the leaks were in the horizontal seams so I can see why they would target the modification like this, but why don’t they test their product properly before sending it out? They just need to tape the vertical seams too and that should provide a product that works ok. Roll on 05S bellows and that being the end of all this! Once again thankful we’ll be looked after by Breeze should ours have issues, the best dealer out there IMO. We have no concerns, just hoping the message gets through to VW so there actually is a 05S on the way….I think we have had the latest dated bellows mentioned so far - 17/01/24 and they leak.
All vertical seams not horizontal. So far.
My confidence in future bellows being a fix is low unless a 05S version comes out.
This is exactly where we were last year with the 03S. I’m a lot more optimistic than I was last year now though. I don’t really know why…I’m not sure a hope that an actual fixed version is on the way is enough for me to hold on to it… it’s a really tough decision.
Do you have any other vans in mind Mark?I’m not sure a hope that an actual fixed version is on the way is enough for me to hold on to it… it’s a really tough decision.
Well, I think we decided it wouldn’t have a pop top next time around.Do you have any other vans in mind Mark?
This issue caused me to rethink the whole issue of bellow per se. I appreciate that most bellows don't leak, but there are other compromises with them. Such as not being able to put them up in very high winds, issues of bedding touching them and getting wet and of course many have issues getting in and out of them.Do you have any other vans in mind Mark?
Only 2 years warranty in EuropeThe optimist in me has to think of this awful situation is that all over Europe , where it’s been raining a lot recently, VW will be swamped with complaints and will have to re think their fix. Even on the new multivan Cali of the future they will need bellows and I’m sure the suppliers will be the same. So ..it will get sorted and we all have a 5 year warranty period for that fix to materialise
It’s certainly a tough call and I wouldn’t blame you one bit for rejecting it, I tried it myself. Since then I’ve tried to reconnect with my van and reflected on all the reasons I chose it over the other options and have got some excitement back again…all of those reasons are still valid even if the bellows situation has been an absolute mess. If you’re set on camper life then definitely have a look around at what other vans are out there before taking a decision, it may help guide you.Well, I think we decided it wouldn’t have a pop top next time around.
A little unsure to be honest at the moment.
The reason we went for the Cali was due to its size. It can go anywhere especially once you’ve added 4motion and diff lock (which we did). I also raised my worry regarding the bellow issue at the start of the process and was told ours would come with the fixed bellows.
If I had known otherwise I’d have cancelled my order.
I think the Zip seams are different in that if water gets under the flaps then it penetrates through the zip itself, not the seams either side.Yes they seem to have added black tape in the horizontal seams but not the vertical seams in the 04S. Not all have shown signs of leakage though so definitely an improvement over 03S. To be fair to them most of the leaks were in the horizontal seams so I can see why they would target the modification like this, but why don’t they test their product properly before sending it out? They just need to tape the vertical seams too and that should provide a product that works ok. Roll on 05S bellows and that being the end of all this! Once again thankful we’ll be looked after by Breeze should ours have issues, the best dealer out there IMO. We have no concerns, just hoping the message gets through to VW so there actually is a 05S on the way….
In my case and many others its comes in through the seam not the zips teeth.I think the Zip seams are different in that if water gets under the flaps then it penetrates through the zip itself, not the seams either side.
You sure you can tell that? Once it's coming through the zip it's going to soak across the inner seam, drip and get worse with any wicking effect.In my case and many others its comes in through the seam not the zips teeth.
