Oceandrive2023
+1 on this ! Just had a fantastic Break in the outer Hebrides . Only 1 night of light consistentI am a new member if the 04S leaking bellows club.
Meant to add, despite+1 on this ! Just had a fantastic Break in the outer Hebrides . Only 1 night of light consistentView attachment 123617 rain and no wind . Post 09/11 04S leaked quite badly ! Actually worse than my original 03S !
Meant to add this pales into insignificance when you are fortunate enough to be in your Cali in Scotland ( Uig Bay ) last Friday !+1 on this ! Just had a fantastic Break in the outer Hebrides . Only 1 night of light consistentView attachment 123617 rain and no wind . Post 09/11 04S leaked quite badly ! Actually worse than my original 03S !
You bas***d..............it was clearly visible here in Norfolk appearing around 11.30 but we'd had a busy day and in bed by 10.30!!!! So many times we've been up there and not seen anything and they appear a day later - arghhhhhhhh!!!!Meant to add, despite
That may become the regular bellows routineEvery other wash TX Direct or Grangers![]()
Welcome to the club no one wants to join.+1 on this ! Just had a fantastic Break in the outer Hebrides . Only 1 night of light consistentView attachment 123617 rain and no wind . Post 09/11 04S leaked quite badly ! Actually worse than my original 03S !
First night out in the rain and no leaks with the 05S. Let’s see if it stays leak free all week
Sounds promising - Keep the forum up to dateFirst night out in the rain and no leaks with the 05S. Let’s see if it stays leak free all week
As photo in post #3758 above it leaves the factory attached to the inner zip of front window.Where can I find the label, I didn't see it.
I have just bought a van registered in dec 23 and the roof is leaking at everywhere… in the process trying to get it sorted by a replacement or returnLooking for other peoples' experiences with the new double lined pop top roof (the one that is grey outside / cream inside), and any potential solutions to the problem of leaking though the seams and fabric.
In the last week we've had complaints from customers on all four of our March 2023 Oceans that the new style pop tops have leaked, mostly though the seams in heavy rain or constant drizzle. Each of them has the new double lined lined pop top roof (grey outside / cream inside). It's not a problem that we had with our "old style" 2022 vehicles (the ones with the single grey pop top fabric) - I think it might be an issue with the new design.
I've read on the forums that putting the pop tops through a few wet / dry cycles will sort the issue as the fibres tighten up - has anyone experienced this with the new style pop top?
If not, has anyone tried something like a Nikwax application to improve waterproofness?
If you've waded through some of this thread you will know that to date, VW have not produced a replacement bellows that is definitely waterproof. Even the latest 05S variant has failed for some owners. If you decide to go the repair route, do so knowing that you may be in for a long wait and that rejecting the van once you have given the dealer an opportunity to fix it may be more challenging, slower and costly. If you are happy to rely on a topper/wrap/can of Aquatex, and want to keep the van, then leaking bellows is a resolvable problem - just not by VW so far!I have just bought a van registered in dec 23 and the roof is leaking at everywhere… in the process trying to get it sorted by a replacement or return
Sorry to hear this.First night in the rain with the new 5S was a 50/50 success, the canvas appears to be water tight around the sticking but I had a pool of water in each front corner internal of the van looks like it is either leaking through the rubber seal at the base somehow or it is through the canvas stitching right at the base. Awaiting dealer response
Ah ha , I looked for a sown in label. If the paper tag is removed guess no way to know which version you haveAs photo in post #3758 above it leaves the factory attached to the inner zip of front window.
Oh that’s not good at all.Bought a brand new cali from Breeze, Poole in March. First time using the pop top in the rain this week on a much anticipated holiday. Had to come home after second night as bedding was soaked by bellows (04s) leaking in multiple places. Also water pooling in back cupboards , soaking our clothes.
We are going to go into Breeze next week and will complain vigorously as they knew this was a problem when we bought it, (Tom@breeze has commented on here about it since Sept 2023!) and chose to say nothing. The camper is not fit for purpose and we will refuse a cover. As my husband says it’s like buying a brand new house and being given a tarpaulin to put over the roof because it leaks!
Didn’t you inform the forum on a separate post that your bellows leaked after testing on 6/5 … did you inform dealer about leak then prior to your holiday When your initial findings seem to have been repeated or for your holiday did you have a replacement?Bought a brand new cali from Breeze, Poole in March. First time using the pop top in the rain this week on a much anticipated holiday. Had to come home after second night as bedding was soaked by bellows (04s) leaking in multiple places. Also water pooling in back cupboards , soaking our clothes.
Yes we tested them on our drive as earlier that week Breeze had found they were leaking when we reported water pooling at the back. We thought we had overfilled the water tank! Bellowsgate was not known to us then!Didn’t you inform the forum on a separate post that your bellows leaked after testing on 6/5 … did you inform dealer about leak then prior to your holiday When your initial findings seem to have been repeated or for your holiday did you have a replacement?
Leaking Bellows: Installed since October 2023 Only
Not sure if it’s glued, can’t tell. I didn’t take any pics of my 03S fabric either so it may be no different. Will see what happens in the wet I guess.vwcaliforniaclub.com
