Repairing or replacing wardrobe door?
MadMechanic
MadMechanic
My wardrobe door has fallen apart (the silver one) I have repaired it with tape but it is still not great.
Has anyone had these repaired under warranty? If not, has anyone repaired one themselves or ordered the new door and fitted it themselves?
Thanks in advance
jeff
jeff
Home is where you park it !
Newbury
T5 SE 174
Repaired it with duck tape. The door is quite easy to take out just unscrew the stops and I think it lifts out or might slide out . It's been ok it was a couple of years ago .
Gasgas
Gasgas
Northamptonshire
T6 Ocean 204
I had mine replaced under warranty last month @vindis Northampton.They have a master technician who does all the work on California's ,I was quite impressed with them all items (about 10 in total)fixed or replaced over two days with a loan car thrown in.
AlanC
AlanC
Traveling
Bristol
T5 SE 180
I had to replace both Tambor doors last year.
They are very easy to replace, just 2 self tapping screws on each door and then slide in. Only available from VW though.
Alan
Joss Apps
Joss Apps
Nottingham
T5 SE 180
I need a new rear door, it's been held together with duck tape for some time now. I'm thinking about getting a fabric type mesh and glueing in to the back, worth a go?
calikev
calikev
Administrator
Staff member
Admin/Founder
Kettering
T5 Beach
We can supply the wardrobe doors
calikev
calikev
Administrator
Staff member
Admin/Founder
Kettering
T5 Beach
Yes which one do you need the front or rear?
calikev
calikev
Administrator
Staff member
Admin/Founder
Kettering
T5 Beach
Rear sliding door £84.99 delivered
MadMechanic
MadMechanic
me too, should be a good market for these as they all seem to fail as soon as your warranty runs out!
calikev
calikev
Administrator
Staff member
Admin/Founder
Kettering
T5 Beach
You better order it from there then.
Add the vat and delivery onto that price you were quoted as our is including vat & delivery
dayslikethis
dayslikethis
Tenby
T5 SE 180 4Motion
My rear wardrobe door has also come apart - the existing tape has come away. I plan to get some good duck tape (clear) and stick it back. A little disappointed that its happened.
Erem
Erem
Bath
T5 SE 180 4Motion
My rear wardrobe door was broken at the first flexible joint. I took it all out (just 2 screws and it pulls out) and noticed that to make the full door 2 flexible panels are used that link together and then on to the front plastic handle bit. As the front section connected to the handle was the bit that was broken I unclipped the 2 sections and attached the original rear section to the plastic handle giving an 'as new' secure fit, then taped the remaining piece to the now secured front section. Really easy and as the front section to plastic handle bit gets the abuse the taped together rear section should last. Time will tell if I have successfully saved the cost of a new sliding door. I would have taken photo's but wasn't expecting it too work;)
