Retro fit RNS 510 no satnav in dashboard
georgemojo
georgemojo
Devon
T5 SE 140
Retrofitted an RNS 510 - all is well apart from not seeing the compass and direction arrows in the dashboard colour MFD in satnav mode. It was fitted by my local VW dealer that I bought the van from. Is it a coding issue? Or am I expecting too much? Any thoughts much appreciated
Coding 100%. Essentially your van needs to be 'told' it has a RNS510 so it can Display the directions on the MFD. 5 minute job.
You need to take it back to the stealers or find someone local with a VCDS cable (or buy one).
If you're close to Brighton or North Devon I'm happy to help.
The fact your VW Dealer doesn't know this is appalling.
Thanks v much for the info and the offer of help. I think I'll firstly go back to the dealer. They said at the time they rarely retrofit RNS 510's so perhaps now by suggesting a solution it will sort itself out.
Yes, very easy with VCDS, there is a box that needs ticking basically, and then you get the compass and full prompts in the MFD. We retrofit loads at our place.
Shocking service by the dealer
Could also be that it needs a firmware update to enable the compass ?
