L
lohr500
Yes, there is an On/Off option in the setup menu.Is it easy enough to turn parking mode off?
Nextbase only recommend setting it to On if using a hardwired power supply kit.
Format the card every so often. There’s an option to do this in the menu.We’ve got a Blackvue front and rear camera. Apart from observing really bad driving, we’ve so far been fortunate in not needing to recover footage. TBH I should check that the memory card is still okay more often. We had one fail early on.
I went and checked it yesterday afternoon - and the SD card was unreadable! I’ve swapped it out for the original BlackVue card and it’s back working. One of the issues I’ve always had is the ability to connect to the camera with my phone (I haven’t gone for the cloud option). It makes it a bit of a chore each time , but I know I should do it more often.Format the card every so often. There’s an option to do this in the menu.
No problems with parking mode been hard wired for about twelve months very easy to wire in rooting wires very easy and it’s wired to the fuse board you have spare fusesAny issues with the Parking mode and the battery? I know it will pick up motion and start recording, worrying that if I get this one it’ll drain the battery
