I have recently had some fire extinguishers put in at home and asked about one for the Cali. They recommended a water mist one as it can be used on most types of fires.I'm thinking of getting one of these.
http://www.safelincs.co.uk/1-litre-water-mist-fire-extinguisher/?gclid=CLWPxYbjlcwCFfAy0wod7dUFHQ
Any views? Has anyone got one or even used one? They are supposedly usable on most types of fire and leave no damage.
Each to his/her own. If you want something that is much bigger, pressurised and weighs 4 times as much (and has lots of snaggly bits on it!) then go for a traditional type extinguisher.
Ordered. Ease of use was a big consideration and if the fire is any bigger than this can handle then I'll not be tackling it anyway. Thanks all.Each to his/her own. If you want something that is much bigger, pressurised and weighs 4 times as much (and has lots of snaggly bits on it!) then go for a traditional type extinguisher.
The Firetool extinguisher does the same/similar/better job with all types of fire at a similar price (and looks cool!)
With it located on the unit behind the Cali passenger seat I still have room to put a waste bin and a coat (and have the bandrup storage pockets on the back of the seat.)
I have one in my car (Eos) as well...
This looks like a really interesting piece of kit. The claims made in the website are impressive but there is no explanation of how it works and what it contains? Also, googling it doesn't throw up any opinion other than that available on the manufacturer's website. I take your point about the larger size and weight of water mist extinguishers but there is plenty of opinion of them from the fire service and others that backs up the manufacturer's claims.Each to his/her own. If you want something that is much bigger, pressurised and weighs 4 times as much (and has lots of snaggly bits on it!) then go for a traditional type extinguisher.
Thats handy, thanks - been struggling (well, you know what I mean) with best place for the blanket.Is there? I found the first aid kit and warning triangle there - but not a fire blanket. I'm going to look.
Edit. @Tink - All I have at the back of the cupboard is this
This is a first aid kit and warning triangle. Did you also get a fire blanket?
I purchased a 1m x 1m fire vlanket and fixed it to the front of the bench seat next to the drawer.
I am thinking of also getting a water mist extinguisher as they can be used on pretty much anything and don't leave the damage that powder, foam (or even water) does. But I'm I want to try to see one first to work out where I can mount it.
Goodness, that sounds somewhat scary; hope you are OK, and really appreciate the post - shows just how easily these things happen - thank you
Mark
It happens in the blink of an eye , glad you managed to put the fire out pretty quick with the blanket...
Is there ny visible damage part from your egoand guess smelll
What a lucky escape. So glad you are ok @GrannyJen.
However I feel that I must strongly advise against getting involved in trying to deal with anything much bigger than a smoldering tea towel. If you have an actual fire in your Cali then don't mess about, quickly get your family and pets out, call the fire service and stay well clear. Vehicle fires can develop rapidly and can involve a range of serious hazards including highly toxic smoke and explosion, to name but two. Once you start dealing with a small fire you may be drawn into continuing long past the point where it was safe to do so. However nice or expensive, no vehicle is worth getting injured for.
Regarding fire extinguishers, they are of course, as the name implies, for extinguishing fires. However, their principal purpose is not to turn the user into a firefighter but to aid their escape.
