2into1
Née T4WFA. Now running 2006 LHD T5 SE 130 Manual
When I installed solar on my T4, the mains charger would cycle on and off every couple of seconds when the sun was shining. (the plugged-in symbol on the overhead display would disappear then reappear). At night or poor light, all was normal. I suspected the charger was being tricked by the higher voltage from the solar panel and would cut itself off. Why it would come back on after a few seconds was less clear.Is it possible that somehow the solar charger tricks the relay into believing the leisure battery is full?
I ended up fitting a cut out switch between my solar and the leisure batt, as I fear such frequent cycling on and off would harm the charger. I only put the solar into action when parked up without hook up.
If your theory is right, then driving at night should see your leisure battery given a big boost by the alternator, but not during daytime driving.
