pjm-84
- Messages
- 2,519
- Vehicle
- T5 SE 180
Date of first registration will be on your logbook at the top. Just checked mine and its correct., i.e the day it was dropped off to me.
M1 doesn’t stand for motorhomeBody Type: MPV
Taxation Class: Diesel car
Vehicle category : M1 (motorhome?)
if it’s registered as M1 with body type MPV the correct tax is the £150 a year + the £350 over £40k supplement.thanks. ours was registered on the day we collected, 20th March, I am absolutely sure about this as there was a delay in our payment going through and nearly were not able to complete the transaction and therefore, register, which was done, only when all monies received by dealer later on the same day.
So it’s no different from mine that says mpv on the logbook ? And is around 450 a year after the first year?M
As you say V5 Cali is a MPVM
Apparently not although I stand to be corrected. Once the class has been set HMRC rules prevent it from being emended.Can you apply to DVLA to reclassify as a Motothome?
I recall a few years ago you were able to reclassify the Cali as PLG I think. There was a letter posted on here from a VWVC that a member used to get DLLA to change the classification. I can’t find it but it may still be relevant as we managed to change our 54 plate cali and save some taxApparently not although I stand to be corrected. Once the class has been set HMRC rules prevent it from being emended.
I'm even more confused having read through the above, as the vehicle category is M1.I'm confused. My registration document gives model as California SE TDI 180 A; body type as Motor Caravan and taxation class as Diesel Car. It's the taxation class that count isn't it?
If what @SusiBus says is correct, VED on my 2013 Cali is going to be higher than that on a new one.
Body typeI'm even more confused having read through the above, as the vehicle category is M1.
It's obviously still the taxation class that governs VED so where does the description Motor home, MPV or other fit in, if at all?
No Motor home class, Motor Caravan was and may be now reapplied to Cali's especially now that the Beach is no longer imported, for now.I'm even more confused having read through the above, as the vehicle category is M1.
Hi,Can you apply to DVLA to reclassify as a Motothome?
I’m curious on this too , as £475 road tax was an unwelcome surprise when I picked up my nearly new Cali Beach in Nov 19, as my old Diesel Verso 2.0 is £130.. do doesn’t anyone know if £270 will be the renewal in Nov 20We got our Cali, new on March 20. paid 1280 first years VED. end of March SORN, and received a refund of, I think 435 being 11 months remaining TAX for the year. Note the comments above, including that rate of new charge (270 pa) cannot be backdated, but also checked re intro rate date, and the new rates came into effect on 12 March, a week before we registered our vehicle. Should we not have paid the lesser rate? should I get in touch with dealer or with DVLA? Do i understand correctly that the new rate of 270 now continues ad infinitum, rather than the previous 475 for the first five years as was previously stated. much appreciated.
I believe its around £450 for the first 5 years then drops.I’m curious on this too , as £475 road tax was an unwelcome surprise when I picked up my nearly new Cali Beach in Nov 19, as my old Diesel Verso 2.0 is £130.. do doesn’t anyone know if £270 will be the renewal in Nov 20
Our T6.1 will (hopefully) be on it's way from Germany soon, so it looks like we will benefit from £325 first year VED (including the £55 registration fee) rather than the £1,335 previously. However, looking at this DVLA document it would also appear that as a Cali is no longer a "car", and is now classified as a PLG vehicle, we also avoid the £40k+ "supplement" of £475 per year for years 2 to 6. Would others concur?Think that the £40K supplement won't apply either with the PLG category???
You are correct. Although the figure of £1,335 would have risen in April to around £1,800.Our T6.1 will (hopefully) be on it's way from Germany soon, so it looks like we will benefit from £325 first year VED (including the £55 registration fee) rather than the £1,335 previously. However, looking at this DVLA document it would also appear that as a Cali is no longer a "car", and is now classified as a PLG vehicle, we also avoid the £40k+ "supplement" of £475 per year for years 2 to 6. Would others concur?
DVLA V149 Rates of Vehicle Tax
My figures are based on how my Cali was categorised last year (Jan 2019). If DVLA has decided to change the classification of a Cali to something different (which I find very unfair) then the rates I quote above may not apply.
