Yes normal, the blue-motion technology allows the alternator to idle(no charge) when the starter battery is over 80%. The fact that you saw greater than 20A is a good sign and means its working as it should.Good morning all,
Just a quick follow on from this, I checked mine last night as I can't remember seeing it charge. I've only had the van just under a year so I'm still not fully up to speed yet so forgive the ignorance.
When the ignition was started it was showing a G on the display but a minus figure on the current. I left it for a while and it was fluctuating in the minus range (between -6 and -4 ish), but I noticed it kicked in to charge (showing >>20A on the display) when I switched on the vehicle lights - which I thought was a bit odd.
Is this normal behaviour? Should it charge constantly or just when some logic decides to switch it on/off? The battery is at about 80% charge so not full, so I guess i'd expect it to start charging as soon as the engine is running.
You’re welcome, pleasure to meet you both, any excuse to get into the A Fuse box
And a new 100A fuse and you’re good to go..
Under the starter battery, there is a big black box. Try to unscrew all the screws, after you put out the battery, plate that holds the battery.Hi there,
Thanks for all of the useful advice on the forum.
I have been trying to solve a very similar issue to this post, leisure batteries charge fine on hookup but not when driving despite G symbol being displayed. New leisure batteries in the last 6 months. Have checked voltage of both leisure and starter battery. I am keen to check the fuses in this photo - but I cannot work out where in the engine bay this is?! Sorry, aware this is likely a very daft question. Any pointers greatly appreciated! Thanks @Loz
Not a very fun job to do...
Probably not much issues.Thanks for the info. I’ll have a look now, is it OK to disconnect the starter battery or will this cause issues? Thanks, Kristee
Yes, its fine for up to 18 hoursVoltage at 80 amp fuse = zero with engine running and also with engine off....thanks @Loz
PS, can I just disconnect the battery without worry of electronic /computer mishaps?
Hi @Loz where is the best place to buy this 100A fuse to keep as a spare?Yes, its fine for up to 18 hours
12v planet, or Fleabay its a 100a midi fuse.Hi @Loz where is the best place to buy this 100A fuse to keep as a spare?
Thanks.12v planet, or Fleabay its a 100a midi fuse.
Hi Loz, I'm having troubles with my starter battery, after abt wk of standing it just starts, it hasn't had any long run outs for a while, all the batteries are newish, it's a 57 plate might a have the diode issue.Engine running and heater on;
Generator symbol
Voltage over 14V
Positive charge current
That all looks normal from a leisure battery point of view and shows its charging okay.Hi Loz, I'm having troubles with my starter battery, after abt wk of standing it just starts, it hasn't had any long run outs for a while, all the batteries are newish, it's a 57 plate might a have the diode issue.
Here are some pics with engine running & heater on, heater on without engine running, & without anything on.
Thanks Liz, that's put my mind to rest, on the pic that shows the heater on with the engine running the 0.02A is showing yours was 8.08A what does that mean, sorry not electrical minded.That all looks normal from a leisure battery point of view and shows its charging okay.
none of that shows your starter battery.
In the extreme cold, all batteries struggle a bit and the starter battery can be depleted by the alarm, anything you leave plugged into the centre dash socket, dash cams and dongles left plugged into the ODB port etc.
My starter battery was down to 50% after 2 weeks in the cold, I just had to run it to charge it up. (can't get it outside to plug it in at the moment)
It means your alternator is covering the draw from the heater.Thanks Loz, that's put my mind to rest, on the pic that shows the heater on with the engine running the 0.02A is showing yours was 8.08A what does that mean, sorry not electrical minded.
Thanks Loz, but why was yours 8.8a & mine 0.02a is it yours was on a higher temperature?It means your alternator is covering the draw from the heater.
The Parking Heater uses a lot of current when starting up. Once upto operating temperature it uses substantially less.Thanks Loz, but why was yours 8.8a & mine 0.02a is it yours was on a higher temperature?
Cheers,The Parking Heater uses a lot of current when starting up. Once upto operating temperature it uses substantially less.
Do your test again and turn the engine off, once the engine stops charging the batteries, you’ll see your current draw increase from the batteries.Thanks Loz, but why was yours 8.8a & mine 0.02a is it yours was on a higher temperature?
