We have 17 radiators.15????? WTF? I don’t think there are 15 radiators in our village! How big is your house?![]()
Ah you beat me Andy, only 14 radiators in our house unless I count the 2 electric ones on the top floor then I trump you with 16. Unless of course you have another lot of undeclared rads with valves that weren’t stuckThats fine, sounds like you're aware.
Works ok if the house is plumbed right. Ours has the biggest most used room is at the far end of the pipe run, even with all other radiators turned off we struggle to get that room hot enough. Really need to re plumb with bigger pipework.
Something else worth checking is if thermostatic radiator valves are working, I checked ours in the summer & found about 15 stuck ones.
That’s just the 15 that we’re stuck, what about the other 15 that were working?15????? WTF? I don’t think there are 15 radiators in our village! How big is your house?![]()
Depends on which hue lamps you have, you can specify in the settings power on options in the later firmware versions, to prevent this type of issue.I’ve noticed that any Hue lights that are fitted in table lamps will come on and stay on following a power outage. Not great if you’re away on holiday.
Just wait till your fixed rate comes to an end that amount will go in less than 3 months.Ah you beat me Andy, only 14 radiators in our house unless I count the 2 electric ones on the top floor then I trump you with 16. Unless of course you have another lot of undeclared rads with valves that weren’t stuck![]()
Mind you now that the kids have gone most are turned right down or off. In fact so far this winter, we’ve only had the CH on if we have grandchildren staying over.
So here’s a question: with energy companies overcharging us all each month and most of us economising as much as we can, how much credit is in your account. Ours is £1407.42 and E.ON Next won’t allow me to reduce my monthly DD !
I switched to a variable direct debit, rather the money was in my account than my energy supplier, that way just pay for what I use each month. Stops the energy company setting high DD monthly payments and just helping themselves to my moneyAh you beat me Andy, only 14 radiators in our house unless I count the 2 electric ones on the top floor then I trump you with 16. Unless of course you have another lot of undeclared rads with valves that weren’t stuck![]()
Hi @TR7_Driver I’ve learned that my Hue hub (round one) is no longer supported. That’s the issue. Won’t be upgrading though as I rarely use much of the functionality anyway.Depends on which hue lamps you have, you can specify in the settings power on options in the later firmware versions, to prevent this type of issue.
We have 17 radiators.![]()
22 in mine, all with thermostat valves, 5 are in an extension with it's own dedicated boiler and the heating mostly switched off.13 radiators. The front room bay window has three small rads; the front bedroom bay above has two.
Think of it the other way round. It's a nice 1kW heater that you can also watch Germany get thrashed on.That said I"m glad I no longer have my 3CRT Sony G90. That was a 1kW beast, with enough heat output to keep all the apartments in the block cozy.
Yep - Our In house display packed up years ago - Gen 1 meter.Apparently we can’t have a smart meter in house display because our smart meters are gen1?
Does this sound right? Anyway round it?
We can't have a smart meter because our leccie comes in at the second floor and gas in the cellar and apparently they can't communicate with each other (despite having wifi everywhere). Doesn't stop the energy companies keeping asking us about every six months if we want a smart meter.Yep - Our In house display packed up years ago - Gen 1 meter.
The meter part still functions and sends EDF meter reads - but no display.
EDF sent me a new one that I spent hours trying to get to talk to the meter unit - no go and eventually they admitted it wont work with the older Gen 1 units.
So will have to wait until they get around to swapping the old Gen 1 units out - which will take years.
More tech that will end up in landfill. The carbon footprint on all this tech isn't without its own concerns right?
The same story with us. I thought our meter was smart ... but it seems not smart enough! Have not found a way around it though as yet. Have been considering this as an addon - https://www.amazon.co.uk/gp/product/B086BNQ1X4/?tag=unique09f-21 to get some data ... but an expensive add on.Apparently we can’t have a smart meter in house display because our smart meters are gen1?
Gen 1 smart meters will only work with the original supplier. Took ours out with Eon years ago and never worked with other suppliers, now back with Eon and it works perfectly.Apparently we can’t have a smart meter in house display because our smart meters are gen1?
Just healthy football rivalry. Doubt many on a VW forum are anti germanA lot of pro radiator/anti German sentiment in this thread![]()
Our Gen 1 unit was supplied by BG and it stopped working when we moved to EDF. About 8 months after moving to EDF I got an email to say they were now collecting smart meter readings. So they managed to get the meter side of things talking back to them ok. But the IHD had packed up. They supplied a new IHD but that is not Gen 1 compatible, so we are limited to meter readings only.Gen 1 smart meters will only work with the original supplier. Took ours out with Eon years ago and never worked with other suppliers, now back with Eon and it works perfectly.
No one taking me up on the true cost of having the oven on?#save-real-ovens
Our ovens seem to be one of the main culprits in this crisis. I do wonder if we have fully understood the true cost of running them....
Where does the heat go that I've just invested in heating my lasagne? Some will have escaped through the external wall behind it, but a good bit of it remains in the lovely warm kitchen and is now spreading around the house (I know that because I can smell the roast garlic from the tray bake).
So does cooking with an oven deserve quite the bad rap it gets? It clearly isn't as simple as the calcs suggest (which assumes all the energy used is lost).
My oven is elec and heating is gas so I do have a four (?) fold penalty in cost per kwhr, but many are already using electricity for their heating.
I suspect old tech light bulbs were similarly punished in the calcs but I can't see them making a comeback!
Obviously my pondering only applies to winter when the heating is needed.
Thoughts?
I agree. It is free heat but surely quite expensive heat and probably in the wrong place. Move the oven to the bedroom?No one taking me up on the true cost of having the oven on?
I wouldn't worry about it personally. Air fryers don't do it for me. It's not a fryer it's a tiny fan oven. Ninja a/f has a 2400w rating, my Falcon fan ovens are 2.5kw each. I know the air fryer is quicker to heat up etc but my oven is huge can take 4 chickens if need be and heats up pretty quickly. How do you do a big tray bake in an air fryer? The difference to me is "small fry" (excuse the pun) and all a bit emperors new clothes. I wouldn't want to look at another lump of black plastic on the worktop. Just my opinion, yet to be convinced.No one taking me up on the true cost of having the oven on?
