Love your van
I’ve been doing some more upgrades preparing for summer trips. Added a Hess HeckBox XL and Front Runner water tank. Nice 20 liters of reserve and easy fill of the van with modified tap with quick hose connects.
Very practical thinking! I wish we had the gear that Hess in Switzerland offered, but at the same time I would probably go broke.I’ve been doing some more upgrades preparing for summer trips. Added a Hess HeckBox XL and Front Runner water tank. Nice 20 liters of reserve and easy fill of the van with modified tap with quick hose connects.
My son wants to do this. Can you advise the process. How easy and cost. Thanks.Retrofitted a Digital Cockpit
Hi there, I'm in Switzerland and assume you are in the UK. In the UK the best place for this retrofit is Leighton Vans. My mechanic in Switzerland provided them the coding required for the retrofit:My son wants to do this. Can you advise the process. How easy and cost. Thanks.
Many thanks @Webbah_in_SwitzerlandHi there, I'm in Switzerland and assume you are in the UK. In the UK the best place for this retrofit is Leighton Vans. My mechanic in Switzerland provided them the coding required for the retrofit:
Electrical Upgrades | Leighton Parts & Leighton Vans
ELECTRICAL UPGRADES Virtual Dash Upgrade your van and your driving experience with a virtual dash - a newly developed feature now offered in-house at our Rotherham HQ The virtual dash upgrade is designed for T6 1 vans with Discover Media Navigation due to it acting as a second interface for this...www.leightonparts.co.uk
Not exactly cheap though. ;-)
Crikey. You're not kidding. Good thing I prefer the analog cockpitHi there, I'm in Switzerland and assume you are in the UK. In the UK the best place for this retrofit is Leighton Vans. My mechanic in Switzerland provided them the coding required for the retrofit:
Does the odometer get reset back to zero or coded to match the original?
How did you fit a 235/65/17 in the rear carrier? have you cut the plastic tray and fitted the larger carrier?Added front and rear recovery hooks and also fitted a spare Tyre BFG KO2. Ready for summer off-road adventures!
I see so you run 235/65/17 on the van and the spare is a 225/65/17?These are 225/65 R17. But yes you do need to cut the plastic a little bit. Not a big deal. I also have an onboard compressor so inflated to 2 bar. And sprayed silicon on the Tyre to slide it right in.
Your picture shows 235/65/17 with the warlords ?
Did you not like the pirelli AT ?I was thinking of going down that route lolThose are the Pirelli Scorpion AT Plus tyres. I went back to BFG as the dealer took them back and did the swap for no charge. He put those on his rental.
