This is exactly what I wanted to know, thank you. May I ask which insurer you found that did not object, please? Your van is lovely.Having both a lower half two tone wrap then later in the same van had a lower half two tone re-spray i feel I'm well placed to answer your questions. View attachment 115858
It is easier to wrap or paint the lower half.
Wrapping does provide some protection to the paint underneath but it is not in the same league as paint protection film.
Some insurers will not cover wraps but some do. Be sure to tell them its wrapped.
No need to inform the DVLA regarding wraps as it is not considered a permanent colour change.
A lower half wrap costs around £3k and will last 5 to 7 max years before you will need to have it removed and re-wrapped.
A lower half re-spray will cost around £4k from an approved VW bodyshop and should last the life of the van.
Don't worry about re-spray affecting the robustness of the paint finish. Since the original factory paint is not removed. They simply key the surface and apply base coat and clear on top. This paint after a few months will be as hard as the factory paint underneath.
My thoughts / advice is
If you want to stealth wild camp then choose a subtle factory colour all over.
If you really keen on a two tone colour combo then paint instead of wrapping as it cheaper in the long run and ages better.
If you like the idea of changing van colour combo after 5 years of ownership then wrapping is the way to go.
If you want to go the extra yard then apply PPF to the lower half of your van to protect the paint against hedgerow scuffs. Cost is about £2k
When choosing a colour I would advise on thinking about how it will complement the Van's interior colour. I have seen some nice coloured Van's but when they open the doors the outside inside colour combination is hideous.
No. If the Decal is on the damaged panel and cannot be replaced after repair you could live without it. If a wrapped body panel is damaged then the body panel has to be repaired , painted with original colour and then wrapped and that's where the problem lies. Can the original wrap be matched? If not, colour discontinued or ageing of original wrap, then the remaining wrap may have to be removed and replaced adding considerably to the cost overall.Isn't a wrap one big decal?!
Not sure if you are referring to it being wrapped or non factory lower half respray.This is exactly what I wanted to know, thank you. May I ask which insurer you found that did not object, please? Your van is lovely.
Sorry, was meant as a bad joke.No. If the Decal is on the damaged panel and cannot be replaced after repair you could live without it. If a wrapped body panel is damaged then the body panel has to be repaired , painted with original colour and then wrapped and that's where the problem lies. Can the original wrap be matched? If not, colour discontinued or ageing of original wrap, then the remaining wrap may have to be removed and replaced adding considerably to the cost overall.
Happened to me. No fault claim after car reversed into NS. Small dent and damaged wrap. Wrap colour discontinued so third party insurance agreed to cost to repair and repaint damaged panel and then re-wrap the whole lower van two tone wrap in an alternative colour that was still available. The cost to do this was almost the same to repair and repaint the whole lower van a two tone colour. So I settled and had the van lower half re-spray by VW approved bodyshop instead of a complete lower half re-wrap. Every no fault bump has a silver lining!No. If the Decal is on the damaged panel and cannot be replaced after repair you could live without it. If a wrapped body panel is damaged then the body panel has to be repaired , painted with original colour and then wrapped and that's where the problem lies. Can the original wrap be matched? If not, colour discontinued or ageing of original wrap, then the remaining wrap may have to be removed and replaced adding considerably to the cost overall.
Looks stunning. What wheels do you have on your Cali?My Candy White 21reg Ocean had 3000 miles on the clock when I bought it my car being white I saw the VW Viper Green colour swatch in the showroom and took the plunge with no regrets.
Was given advice in Scotland on our first week away to avoid parking near certain football stadiums (getting keyed) we all in the club share one thing in common whatever we coat them in we love our Cali’s….
The alloys are called ‘Devonport’ but are often referred to as Davenports. Regardless of the name they are really easy to clean and plentiful on the second hand market so inexpensive to replaceI thought I had the name somewhere of the alloys but can't find it...I think they are 17" Davenports Michelin Agilis 3 fitted
