Elmo3
Quite ridiculous isn’t it. The van has a perfectly good audio system in it that you can’t use when camping for risk of the starter battery going flat. The solution is to carry more ‘stuff’ around with you!
A question for the more technical amongst us - if on hook up, is this still a problem as I believe the hook up will trickle charge the starter battery once the leisure batteries are at 100%?
