Jimmylondon07
Yeah not so easy on your own I agree, but then I’d probably just keep the roof down whilst raining in that case.Sure. A wrap will work for some.
No brainer?
They could be a little tricky if your'e on your own, or maybe if your're less tall, less fit...
I carry 2x collapsible 11” footstools in the underbed draw which definitely make the fitting job a bit easier when there’s a couple of you. I also assume (maybe wrongly) that the Cali requires a basic level of fitness in itself with all the lifting/moving/climbing you need to do to make use of it! I don’t find putting the wrap on any more physically taxing than climbing in to the roof bed for example.
