I will do it was a little late when finishing last night
Sent from my VOG-L09 using Tapatalk
Was it fuse 18 in the upper fuse bank?
https://www.autogenius.info/vw-tran...rom-september-2009-2014-fuse-box-diagram/amp/
Fuse holder B (Upper)
Fuse Ampere rating [A] Description
1.(25A/30A) Heater A/C (some models)
2.(5A) Steering position sensor
3.(10A) Multifunction control module1
4.(10A) Headlamp adjustment
5.(15A) Headlamp
6.(15A) Headlamp
7.(15A) Multifunction control module1 (interior lamp)
8.(5A) Data link connector (DLC)
9.(15A) Brake pedal position
10.(10A) Windscreen wipers (rear)
11.(5A) Licence plate lamp
12.(15A) Cigarette lighter
13.(5A) SRS control module
14.(30A) Auxiliary heater, heater / A/C
15.(7.5A) Air conditioning
16.(5A) Multifunction control module 1
17.(5A) Rear fog lamps
18.(5A) Instrumentation control module
19.(5A) Audio unit, Instrumentation control module1, navigation system,
20.(5A) Side lamp left, LH Stop lamp, LH Tail lamp
21.(5A) Side lamp left, RH Stop lamp, RH Tail lamp
22.(10A) Airbag assembly deactivation warning lamp, (DLC), Instrumentation control module.
23. (25A, 40A) Starter motor (some models with M/T)
24. (5A) Steering position sensor
25. (5A) Air conditioning
26. (30) Headlamp switch
27.(15A) Headlamp Right
28.(15A) Headlamp high beam warning lamp, Headlight Right
29.(10A) Load area door signal relay
30.(10A) Heated windscreen washer jets, rear screen wiper motor
31.(30A) Multifunction control module 1 (Horn)
32.(25A) Multifunction control module 1 (windscreen wiper motor)
33.(15A) Audio unit, Navigation system, Traffic information control module
34.(25A) Automatic transmission, Fuse box/relay plate engine bay 1 (F3, F12, F14-F17, F19, F20, F24)
35.(5A) Instrument illumination
36.(25A) Multifunction control module1 (Indicators)
#12 (15A) fuse is Cigarette lighter fuse very often blown and asked for location - blue fuse, top row, 3rd from the right.
#10 (10A) Washer wiper fuse - This is the fuse panel on the dashboard below the cigarette etc drawer.
Note 1) for models with roof console only
Fuse holder C (Lower)
1 15A Trailer detector control unit -J345- 15a -10-pin connector -T10bh/1-75a
2 5A Interior monitor send and receive module 2 -30-G305- Anti-theft and tilt system control unit -J529-
3 10A Red Cross light switch -E10- 30 15 A-Red Cross light warning lamp -K100-
4 10A Differential lock control unit -J187- 15a- Rear differential lock switch -E121- -Four-wheel drive control unit -J492
5 5A SC5-10A-6-pin connector -T6bn/5-75x
6 5A Oil level and oil temperature sender -G266-15
7 30A Rotating light switch -E162- 30 10 A
8 5A Parking aid control unit -J446-30
9 5A Steering column electronics control unit -30 J527- Adaptive cruise control unit -J428-
10 10A Left headlight range control motor -V48- 15 5 A-Right headlight range control motor -V49- Switches and instruments illumination regulator -E20
11 15A Left sliding door control unit -J558-58
12 5A Left day driving light bulb -L174-30 30
13 5A Drive train CAN bus isolation relay -J788-15
14 5A Right day driving light bulb -L175–30A
15 5A Mobile telephone operating electronics 15-control unit -J412-
16 7.5A. Navigation system tuner for TV -J415- 30-Interface for external multimedia unit -R215-
17 7.5A Onboard supply control unit -J519- (T73/66) 30 1) -1) 30G 2) Interior lights and compartment lights 2)
18 5A Air conditioning system control unit -J301- 30- Rear fresh air blower switch -E179- – Operating and display unit for rear -Climatronic -E265- Rear blower regulation sender -G463-
19 5A Automatic anti-dazzle interior mirror -Y7- 86s
20 10A Onboard supply control unit -J519- 30 (T73a/64)
21 5A Rain sensor -G213-RPL
22 5A Air conditioning system pressure switch -15-F129- Air quality sensor -G238-
23 10A Residual heat relay -J708- 30a- Remote control receiver for auxiliary coolant -heater -R149- Auxiliary heater operating and display unit -E407- Operating and display unit for camping equipment -E153-
24 7.5A Left centre reading light -W39- 30G- Right centre reading light -W40- – Rear left reading light -W11- – Rear right reading light -W12- – Left interior light -W16– Right interior light -W17- – Rear left interior light -W47- -Rear right interior light -W48-
25 25A Seat heating control unit with regulator -J396-
26 10A Tachograph -G24-30
27 30A D51 Positive connection 1 (15), in engine 15 compartment wiring harness – Fuse 13 on fuse holder D -SD13- -Fuse 23 on fuse holder D -SD23-
28 5A Mirror adjustment switch -E43- 15-Exterior mirror heater button -E231-
29 25A Heater control unit -J162-30
30 5A Operating and display unit for camping 75-equipment -E153- Auxiliary coolant heater relay -J493-
31 25A Sliding sunroof adjustment control unit -30 5 AJ245-
32 20A Headlight washer system relay -J39-15
33 5A Tachograph -G24-15
34 5A Vacant15
35 20A Onboard supply control unit -J519- 30 (T73b/11)
36 5A 10-pin connector -T10bh/9-30
Note:
1) for models without roof console only
2) for models with roof console only
