reserves
Have you tried it with the engine running?
Yes, should have said. Same result
If at home plug in EHUYes, should have said. Same result
As per previous fuse diagram SC 55 ...Thank you. Been out all day (kids birthday) so haven’t had time to check the fuses.
This is my fuse box (behind the bottle compartment drawer) not sure how it relates to the above but I’m happy to check each 5A fuse individually as I’ll be pleased if this fixes it.
Thank youc very clear.
Worth taking out the control panel unplugging the connectors then plug them firmly back in and refit the control panel then try the roof!
Are you sure your starter battery is full charged. People have reported in the past the same problem that you have and it was down to needing a new starter battery.Going to test the fuses & feeds.
Count down, 5 days till France!
Looks like SC56 is the fuse for the ECU which is fed from the ignition starter switch so you may still have an issue with your ignition switch, you may need an electrician or @Loz may be able to help further??? Hope you get it sorted!Thanks for this.
I seem to have an issue with *SC56* whilst SC55 is fine
There is no power going to SC56 either side of the fuse, regardless if the ignition or engine are on.
I know the ignition switch is working as SC55 only powers when ignition is on.
Thanks! Running out of time and patience!!Looks like SC56 is the fuse for the ECU which is fed from the ignition starter switch so you may still have an issue with your ignition switch, you may need an electrician or @Loz may be able to help further??? Hope you get it sorted!
