Roof Won't Open - "Ignition On!"
Assignment of the fuses in the instrument panel (fuse holders C and B)
AmpsFunction/component
Fuse holder B
SB125AFresh air blower isolation relay
SB130A2003:
Rear blower Bitron regulation motor
X-contact relay
2004-2009:
SB25ASteering angle sender
SB310AOnboard power supply control unit
SB410AHeadlight range control regulator
Left headlight range control motor
Right headlight range control motor
SB515ALeft headlight twin filament bulb
Left headlight dipped beam bulb
Special vehicle fuse 3
SB615ALeft headlight twin filament bulb
Left main beam bulb
Special vehicle fuse 6
SB715AOnboard power supply control unit (interior light)
SB85A16-pin connector, diagnostic connector
SB910A/15ABrake light switch
SB105A/10AIntermittent wiper switch
Rear wiper switch
SB115ANumber plate light
Switches and instruments illumination regulator (2003)
SB1215ACigarette lighter
SB135A2003-2004: Brake light additional relay
2004-2009: Airbag control unit
SB1430A2003-2006:
Fresh air blower switch
Air conditioning system switch
Auxiliary coolant heater relay
Front blower Bitron regulation motor
2008-2009:
Headlight dipper/flasher switch
SB157,5AAir conditioning system switch
Fresh air/air recirculation flap switch (2004-2009)
Rear fresh air blower switch (2004-2009)
Climatronic control unit
Air conditioning system compressor regulating valve
SB165AOnboard power supply control unit
SB175ARear fog light cut-out contact switch
Rear fog light warning lamp
Rear left fog light bulb
Trailer socket
SB185AControl unit in dash panel insert
SB195AOperating and display unit for camping equipment
Control unit with display for radio and navigation system
Roof hydraulics control unit
Radio
Special vehicle fuse 1
SB205ALeft side light bulb
Left tail light bulb
Left brake and tail light bulb
10-pin connector, purple
Trailer socket
SB215ARight tail light bulb
Right side light bulb
Right brake and tail light bulb
Trailer socket
SB227,5A/10AControl unit in dash panel insert
Front passenger side airbag deactivated warning lamp
16-pin connector, diagnostic connector 2
SB2325A/30A/40AStarter
SB235AStarter inhibitor relay, 10-pin connector, yellow
SB2325ATrailer socket (2003)
SB245ASteering angle sender
SB255AAir conditioning system switch
SB2630ALighting switch
SB2715ARight headlight twin filament bulb
Right headlight dipped beam bulb
Special vehicle fuse 4
SB2815AMain beam warning lamp
Right main beam bulb
Special vehicle fuse 7
SB2910A2004-2009: Dual signal inverter relay
SB3010ARear window wiper motor
Rear left wing door window wiper motor
Rear right wing door window wiper motor
Left washer jet heater element
Right washer jet heater element
SB3130AOnboard power supply control unit (signal horn)
SB3225AOnboard power supply control unit (windscreen wiper motor)
SB3315AControl unit with display for radio and navigation system
Traffic information control unit
Radio
SB3425A2003:
Speedometer sender
Air mass meter
Automatic gearbox relay
Engine control unit
2004-2009:
Positive connection 1 (15), in engine harness
Fuses on fuse holder D (engine compartment): №3, 12, 14, 15, 16, 17, 19, 20, 24
SB355AInstruments illumination
SB3625AOnboard power supply control unit (turn signal)
Fuse holder C
SC125A/15A2003: 12V socket 2
2004-2009: Trailer socket
SC25AInterior monitor send and receive module (2003)
Interior monitor send and receive module 2
Anti-theft and tilt system control unit (2004-2009)
SC35A2003-2007:
Right auxiliary blower
Left auxiliary blower
SC330A2008-2009: Onboard power supply control unit (heated rear window
SC410A/15A2003:
12V socket 3
2004-2006:
Four-wheel drive control unit
2007-2009:
Rear differential lock switch
Differential lock control unit
SC510A/15A2003: Refrigerator box
2004-2009: 6-pin connector, grey
SC65AOil level and oil temperature sender
SC710A2003: Switch-over relay 1 for roof ventilator
2004-2009: Positive connection -6- (30), in main wiring harrness (roof ventilator)
SC715A2005-2009: 12V socket 4
SC85AParking aid control unit
SC95AMultifunction steering wheel control unit
SC1030AAmplifier
SC1115A2004-2009: Rear lid control unit
SC1120AAlarm horn (2004-2009)
Convenience system central control unit
Left sliding door control unit
Right sliding door control unit
SC125A/10A2003:
2004-2009:
SC135ACruise control system switch
Operating unit in steering wheel
Airbag coil connector and return spring with slip ring
SC145AMobile telephone operating electronics control unit
SC155AGearshift indicator control unit
SC165AControl unit with display for radio and navigation system
Mobile telephone operating electronics control unit (2004-2006)
SC175A/7,5AOnboard power supply control unit (interior light)
Positive connection -1- (30), in main wiring harrness
Rear Climatronic operating and display unit (2003-2004)
SC185ARear fresh air blower switch
SC185A2004-2009: Rear Climatronic operating and display unit
SC195AAutomatic anti-dazzle interior mirror
SC2010AOnboard power supply control unit (heated exterior mirror)
SC215A2003: Interior monitor send and receive module 1
2004-2009: Anti-theft and tilt system control unit
SC225AHigh-pressure sender
Air quality sensor
SC235A/10AOperating and display unit for camping equipment
Auxiliary heater operating and display unit
Residual heat relay
Remote control receiver for auxiliary coolant heater
SC245A/7,5A2003-2004: Operating and display unit for camping equipment
2004-2009: Positive connection in roof wiring harness (interior lighting)
SC2515A/25AHeated driver seat regulator
Heated front passenger seat regulator
Heated front seats control unit
Heated front passenger control unit
Front passenger seat temperature sensor (2003)
SC2610ATachograph (models with tachograph)
SC2615A2004-2009: 12V socket 2 (Multivan without tachograph and second battery)
SC2715ALeft fog light bulb
Right fog light bulb
SC285AMirror adjustment switch
Driver door control unit (2006-2009)
SC2925AAuxiliary heater control unit
SC305AOperating and display unit for camping equipment
SC305AAuxiliary coolant heater relay
SC3125ASliding sunroof adjustment control unit
SC315A2006-2009: Onboard supply charger unit (camper only)
SC3220AHeadlight washer system relay
SC335ATachograph (models with tachograph)
SC3315ATachograph (models with tachograph)
Folding exterior mirror control unit (models with tachograph and electric folding exterior mirror)
SC3315AFolding exterior mirror control unit (2006-2009)
SC3410A/15A/20A/25A2003:
Vacuum pump for brakes
2004: Trailer socket
2004-2009:
12V socket 3
SC3510AOnboard supply control unit (reversing light models with automatic gearbox)
SC365A/15A2003-2004:
12V socket 4
2004-2009:
10-pin connector, purple (models with electric interface only (UF1))
So I had this problem last year.
Just to be clear, the issue you have is that the roof checks that the ignition is on, not because it needs power but it’s a safety thing so that kids can’t open / close the roof as they won’t have the keys, only with the key in the ignition and the ignition on will the roof be allowed to open / close.
I don’t know exactly what fixed mine in the end, I took the relays out from under the seat and put them back in, i sprayed some with contact cleaner.
I removed and put the fuses back in a few times.
It started working and has been fine since.
Fuse holder B
SB130A2003:
X-contact relay
2004-2009:
Left main beam bulb
Rear wiper switch
SB1430A2003-2006:
2008-2009:
Trailer socket
Radio
Trailer socket
Trailer socket
Radio
SB3425A2003:
Speedometer sender
Air mass meter
Engine control unit
2004-2009:
Fuse holder C
SC35A2003-2007:
SC410A/15A2003:
12V socket 3
2004-2006:
2007-2009:
SC1030AAmplifier
SC125A/10A2003:
2004-2009:
Air quality sensor
Residual heat relay
2004-2009:
12V socket 3
12V socket 4
2004-2009:
Yes, have read your previous post and know perfectly the matter of safety, the strange things is that if I leave the key with the CU central button pressed, the message change from
Yes, have read your posts about that, I know perfectly the matter of safety and the choice of German engineer about the protection function of the CU.
In my case, the insertion of the key is recognized, duerning the request to close or open the roof, if I leave the key, the message on CU change from : Ignition on? the vehicle is stops? to: ignition on!
this confirm me that there is dialogue from vehicle to CU but this is not sufficient, probably there is another necessary feed.....
Have tried to leave and insert, sprayed with contact cleaner all the fuse and connectors under the left seat but nothing change!
from that the decision to bypass the CU and install a simple circuit with 2 relays, this work perfectly and maintain all the safety of the CU.
Fuse holder B
SB130A2003:
X-contact relay
2004-2009:
Left main beam bulb
Rear wiper switch
SB1430A2003-2006:
2008-2009:
Trailer socket
Radio
Trailer socket
Trailer socket
Radio
SB3425A2003:
Speedometer sender
Air mass meter
Engine control unit
2004-2009:
Fuse holder C
SC35A2003-2007:
SC410A/15A2003:
12V socket 3
2004-2006:
2007-2009:
SC1030AAmplifier
SC125A/10A2003:
2004-2009:
Air quality sensor
Residual heat relay
2004-2009:
12V socket 3
12V socket 4
2004-2009:
So
The control panel has a number of power supplies.
I have downloaded the T5 circuits from the resource section.
I believe that SC36 (5A) is the "Ignition" feed that is the issue. I would check for voltage on this fuse when the ignition is on. Pin 30 on 32 Way connector
SC30 (5A) is another feed - I don't believe this will give this error.
I am happy to try and help, but always trying to do this remotely is difficult!
So
Thank You!!
I have understand what have to control, in the next days will verify the signal on the pin of the CU rear connectors, thanks for the scheme.
I don't have permission to download from the resource section, what I have to do?
Thank You!!
You have to have VIP membership to access the resource section.
