Little owl1963
Understood so those 2 heaters i take it are in addition to the normal coolant engine cab standard heater , so total heaters amounts to 3 in total plus the air condioning ??For heavens sake.
The Eberspacher heater is the Diesel powered Parking Heater. It is operated from the Control Panel in Continious Heat mode and can run as long as you have electric power from the leisure batteries and diesel in the tank.
The Heater remote control will start/stop the Eberspacher heater in Immediate Heat mode. This is used to warm up the vehicle or de-ice it and will run for a maximum 2 hrs. The timer is reset by driving the vehicle.
The Webasto heater heats the engine coolant to warm up the engine. It is automatic and only functions when the ambient temperature is 5c or below and the engine is started. It switches off when the coolant temperature reaches 75c. There are No manual controls for it.
I think it is time for you to sell your California and get something less sophisticated.
Understood i have 2 x auxillary heaters but if view post 41 , states in manual option the warm windscreen or front interior ?? via mobile app via a mode ?? i have the app and as iv said cannot see this option or mode to enable it ??
Also post 48 states , i presume if have this 2nd webasto heater there are vents on passenger side of vehicle which iv never seen ?? i will check when get van back of Volkswagen .
