Basically the Norwegian Ambulance Fleet had engines from the 2010/11 batch. The base vehicles were then converted into Ambulances that worked under some of the harshest conditions , full throttle/cold engines/short journeys which exposed the fault . Changed and fitted with same EGR that was currently available, A type.That is a very confused statement. "I think you would find, if examined in detail, the Norwegian Ambulance service engine change has very little to do if anything with this supposed problem relating to the EGR. The fleet had the engines changed and guess what " A " suffice EGR assemblies fitted."
That begs the question 'why did they do it'? Why change engines of a national fleet of ambulances? No operation would want to spend that amount of money unless there was a very good reason. If the vehicle supplier instituted the change, then they would also need a good reason, even if they were supported by VW Norge.
As most van sales are fleet sales, I doubt we would know how many of those were affected or resolved either by having new engines fitted or being sold because of the issue.
When my van went in to have the engine changed in 2016, it was the third van to have this work done that month, according to my Service Manger. Just by scaling that up across the official dealer network gives some indication of the potential numbers with this issue.
The Facebook page is private owners who do not have the resources to take on VWUK or VW Germany.
BTW, following the new engine being fitted in 2016, I also changed the service period to yearly and for the last two years, covering a total of 19k miles, have not consumed any oil between changes . That is absolutely none, and I do check my engine fluid levels regularly.
Alan
Manufacturing defects on T5 and A5
“Norwegian ambulances cannot handle emergencies” states VG. Newspapers across Norway have reported problems with Volkswagen T5-based ambulances. Almost all of them have got their engine…
