Loz
Depends on which door modules you have, only a scan with vcds will tell.Is mirror folding configurable via VCDS on 2017 models?
when sat in the van with engine running, do your windows go up automatically with once click of the window switch or do you have to keep the button held upWindows go up when I hold the lock button (if they are open). I would like the mirrors to fold when I lock the van, like they do on our Golf. It's a great visual cue that the vehicle is locked.
One click, but if they stick or come back down due to the safety feature, you may have to reset the one-click.when sat in the van with engine running, do your windows go up automatically with once click of the window switch or do you have to keep the button held up
They should do, if they don’t they need to be recalibrated. From memory, you do this by switching ignition on, winding the windows down then back up again, then switch off ignition.when sat in the van with engine running, do your windows go up automatically with once click of the window switch or do you have to keep the button held up
That must be another solution!One click, but if they stick or come back down due to the safety feature, you may have to reset the one-click.
Easy to do:
Starting from the closed position, lower the window, holding the switch down for 5 seconds once the glass has reached the bottom of the frame
Raise the window holding the switch up for 5 seconds when the glass gets to the top of the frame. The control unit now knows it's top and bottom limits and should function correctly with one touch.
We were going at the same time. Basically the same. From memory, I think you can hear it clicking when holding it at the top.That must be another solution!
If you turn the light switch to 0 then they don’t come on when unlocking.The front lights switch on when unlocking the car. Quite ennoying when you do this on a camping during the night -> unlock the car two times, 3rd time the lights do not switch on.
Verzonden vanaf mijn iPhone met Tapatalk
Am I right that if you have a heated rear screen on an SE/Ocean, the standard double glazing on the rear screen has been eliminated? The configurator, in all it's VW wisdom, neglects to tell you that. I think the Beach comes standard with the un-doubleglazed, heated version.I thought all Beaches have?
Yes that’s correct: sliding side windows also eliminate the double glazing that would be there otherwise in a beach.Am I right that if you have a heated rear screen on an SE/Ocean, the standard double glazing on the rear screen has been eliminated? The configurator, in all it's VW wisdom, neglects to tell you that. I think the Beach comes standard with the un-doubleglazed, heated version.
I'm talking about the Beach VW comfort mattress here, one side, the side that tapers at the edges, is meant to go face down on the flattened bench to adapt to the bench's bumps and lumps, the other flatter softer side is meant to sleep on, very comfortably I might add.VW comfort mattress has two sides, being firm and soft...........
Please confirm.
Didn't know that. Have to go and have a look.The larger picnic table can be clipped on to the kitchen work surface (or just sit free standing) to have a really big table INSIDE for 4. Perhaps everybody knows this already but I found it v exicting!
Apparently VW have now eliminated the two clips (on the Ocean, Beach still has them) that made this possible.Didn't know that. Have to go and have a look.
I “discovered” that you can open/close the two electrical windows if the ignition is off and the doors unlocked by pressing the drivers side window button for a few seconds.
A bit the same as pressing long in the key fob.
Noticed this while I was waiting for madam in the shops and was ideally playing around pressing buttons for no reason
Useful ever since as you sometimes want to have the windows open while camping and don’t have to fumble with the keys.
I didn't know that. I just went out and tried it.If activated you can close the windows from outside the van with the remote key fob!
Sent from my BlackBerry 9800 using Tapatalk
I would really like to have this feature, but it doesn't seem to work on my 2013 SE140.I “discovered” that you can open/close the two electrical windows if the ignition is off and the doors unlocked by pressing the drivers side window button for a few seconds.
IF you have bought one of the the 'unofficial' VW-logo'ed mats from a VW festival (the large mat, around £40 I think) then it's the perfect size for the front and rear tyres to sit on top of the corners. This stops the mat from blowing away, without the need for pegs of any kind!!!
I tried this on a few occasions during my summer jaunt in France, and it was simply a case of dropping the mat where I want it then drive the two wheels on and job done.
It's the little things that make all the difference
Regards, Simon.
